O-Ring Style Calipers
Old Jan 17, 2010 | 06:34 PM
Tim81's Avatar
Tim81
Default O-Ring Style Calipers
My rear O-ring style calipers are leaking. Can anybody tell me where I can purchase a rebuild kit with just the rubber parts. I can find kits for original style seals but nothing for the O-ring style.
Thanks Tim
Old Jan 17, 2010 | 06:36 PM
turtlevette's Avatar
turtlevette
St. Jude Donor '03,'11
Thanks Tim
Vette Brakes and Products VBP has them.
Old Jan 17, 2010 | 08:34 PM
Tim81's Avatar
Tim81
Thanks turtlevette, I check them out and I am concerned with the fact that their kit will only fit VBP pistons. Not sure what makes them different from others. Tim
Old Jan 17, 2010 | 10:11 PM
turtlevette
Do you have the zero tolerance pistons? I got my seals for ZT pistons from VBP. You're ok.
Where did you get the calipers?
Old Jan 17, 2010 | 10:25 PM
Tim81's Avatar
Tim81
I don't know where the calipers came from, they were on the car when I purchased it. The piston clearance to the bore is very close, so they might be close tolerance. I think I go ahead and try the seals from VBP and hope I get lucky. Thanks you have been very helpful....Tim
Old Jan 17, 2010 | 10:32 PM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
Its been a while since I rebuilt my calipers with the VBP O-ring kit, but when I got my kit it came with new pistons also. Easy enough to do if you have never done it. Just be careful when taking out the bore seal so you don't score the caliper bore. When I did mine it seems like the price was around $100 for all four calipers. Good luck with it and let us know how it turns out for you.
Old Jan 18, 2010 | 09:22 AM
Van Steel's Avatar
Van Steel
Premium Supporting Vendor
VBP stamps their calipers. Look for a stamping to have VBP or LS. The LS would be from Lone Star. There are a couple guys rebuilding these but I'm not sure if they put a stamp on them or not. I know these 2 companies do.
Old Jan 18, 2010 | 09:59 AM
zigvs's Avatar
zigvs
I thought the point to o-ring calipers was that would not leak
Old Jan 18, 2010 | 10:05 AM
wcsinx's Avatar
wcsinx
Any piston can leak.
OP the VB&P kit is top notch quality. If you're concerned about the dubious origins of your components, then why not just spring for their kit? It's only ~$200 for all 4 corners IIRC, and it will replace everything but the caliper cores themselves. That's a small price to pay for piece of mind and safety.
Old Jan 18, 2010 | 10:35 AM
Lee H's Avatar
Lee H
Most people use these to prevent leaks caused by air pumping due to rotor run out. O-rings like all other seals wear out over time, heat, poor cyl prep, garbage on the fluid, etc, will cause any seal to leak. I've had o-ring seals in both my vettes for many years with no problems. I orignally installed them because I could not stop the leaking with the standard lip seals.
To O-Ring Style Calipers
