What power valve to use
Old Mar 5, 2002 | 04:55 PM
BLT-71's Avatar
BLT-71
Default What power valve to use
I need to know which power valve to use on my vette.
The vacuum is much better now after the rebuild and the new cam.
The gauge reads 19-20 at 750 rpm (idle), I use to only have 11-14 at idle.
I have a Holley 3310-4. My rebuild kit came with a 7.5 or 6.5, I can't remember at the moment.
Do I need a different one for the carb to work properly??
Thank You in advance. :confused:
Old Mar 5, 2002 | 05:33 PM
yellow 72's Avatar
yellow 72
St. Jude Donor '09
Default Re: What power valve to use (BLT-71)
The best way to select a power valve is to observe manifold vacuum reading during steady cruising speeds and use a valve that opens about 2 in. below the lowest STEADY reading :cheers:
[Modified by yellow 72, 3:35 PM 3/5/2002]
Old Mar 5, 2002 | 06:38 PM
Kingt's Avatar
Kingt
Default Re: What power valve to use (yellow 72)
Holley has a site for this process. http://www.holley.com/HiOctn/TechSer...o/TI-222A.html
To What power valve to use
