Air Gap Users
Old Mar 5, 2002 | 07:07 PM
rayray's Avatar
rayray
Default Air Gap Users
When I went to put my carb. on my intake, I found that it covers the only hole in the intake to use for air to the brake booster. Can I use the air from the big fitting on the base of the carb. for the booster? Thanks Ray :chevy
Old Mar 5, 2002 | 07:33 PM
ram82fire's Avatar
ram82fire
Default Re: Air Gap Users (rayray)
YUP !! :rolleyes:
Old Mar 5, 2002 | 07:36 PM
Captain Morgan's Avatar
Captain Morgan
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Default Re: Air Gap Users (ram82fire)
I'm hoping that Edelbrock will make the Air Gap manifolds for the quadrajet. They make the Performer and RPM for Q-jet, why not Air Gaps? That way I wouldn't need a spacer or have to switch to a different carb.
Old Mar 5, 2002 | 08:01 PM
gearheadz's Avatar
gearheadz
Default Re: Air Gap Users (sharklover)
How about a Performer Air-Gap (non-EGR) #2601?
Mark
[Modified by mdsmith, 7:02 PM 3/5/2002]
Old Mar 5, 2002 | 08:03 PM
gearheadz's Avatar
gearheadz
I put a one inch spacer under the carb so the fitting would clear & I could retain the factory steel tube to attach the booster hose. I used the carb base vacuum port for the PCV valve.
FYI...Edelbrock makes a low profile vacuum fitting for the intake that supposedly clears the rear bowl on the carb w/o any spacer.
http://www.jegs.com/cgi-bin/ncommerc...643&prmenbr=76
Mark
Old Mar 5, 2002 | 08:10 PM
Aaron-74's Avatar
Aaron-74
Default Re: Air Gap Users (mdsmith)
I want the performer Air-Gap. I don't know if it will fit under the stock hood. I would like to see the gains from the normal perfomer to the air-gap.
Old Mar 5, 2002 | 08:58 PM
JHL81's Avatar
JHL81
I have my brake booster hooked up to the carb and it works no problem.
J.
See and Hear my 81 at www.Genuine-Chevrolet.com
Old Mar 5, 2002 | 09:48 PM
Captain Morgan
Cruise-In V Veteran
Mark
I didn't realize they were making it so the Q-jet would fit without an adapter.
[Modified by sharklover, 7:54 PM 3/5/2002]
Old Mar 5, 2002 | 09:52 PM
Aaron-74's Avatar
Aaron-74
Since my Holley doesn't have A. the clearance or B. the port for it. I'm going to run my power brakes through the 3 port adapter on my intake.
Old Mar 5, 2002 | 10:13 PM
rayray's Avatar
rayray
Thanks for all the response. I didn't think about the PCV valve. Where would I connect it to. Any ideas? I'll check with Jegs about the fitting Part# 350-8096, thanks Ray.
Old Mar 6, 2002 | 12:25 PM
Steve Straus's Avatar
Steve Straus
I think this "Air Gap" thing is so funny. People are looking at them like they are something new. Original Buick, Pontiac, Chrysler, International, and some Fords all had the same basic design from the factory. It was a two part thing where you had a valley cover that buttoned up the lifter valley, then the manifold just went over that. It looked just like an air gap when you were done, but it was usually iron and not aluminum. Look at an edelbrock intake for a Pontiac 400 and you'll see what I mean.
The Air Gap is a sweet manifold, I just think it's funny that they're making it out like it's new technology.
Old Mar 6, 2002 | 12:53 PM
bigvette1's Avatar
bigvette1
Ram82fire is right. If you are running a Holley (Avenger) or other the large fitting is manifold vacuum and that is what the brake booster needs. Strange the Air Gap did not provide a fitting hole for manifold vacuum?
To Air Gap Users
