How much HP difference do mufflers make?
Old Mar 5, 2002 | 08:40 PM
damac's Avatar
damac
Default How much HP difference do mufflers make?
I am upgrading my stock squared off 2.5 inch exhaust on my 65 sb coupe to a true round 2.5 inch system with an X-pipe. I am currently running Dynomax trubo mufflers that flow 370 cfm (per dynomax). Dynomax told me that the ultraflow mufflers will flow 1,100 cfm. I am running a pretty healthy 406 (see sig).
Is it worth the $$ to upgrade to the ultraflows? The flow #'s sure seem to say so, but I don't know how much flow I need to support my 406.
Thanks,
Mike
Old Mar 6, 2002 | 01:16 AM
Les's Avatar
Les
Default Re: How much HP difference do mufflers make? (damac)
I'm running 2 1/2" in & out SS Ultraflos & am very happy w/ them. I definitely felt the difference between them & the turbo type muffs that they replaced. The SS type is pretty expensive due to the finish but you can now get the same muff w/ standard finish for a pretty good price. FYIW, the sound is just what I was looking for- raspy burble at idle, quiet at cruise, & nasty when you hit the throttle.
Old Mar 6, 2002 | 11:22 AM
damac's Avatar
damac
Default Re: How much HP difference do mufflers make? (Les)
Les,
Thanks for the info. That sounds like the exhaust note I am looking for.
Mike
Old Mar 6, 2002 | 11:28 AM
Aaron-74's Avatar
Aaron-74
Here are my mufflers. Dyno Max Race Magnum Bullets. I don't know what CFM there flowing, I don't know but it seems like they would flow a LOT! :cool:
Old Mar 6, 2002 | 11:29 AM
Aaron-74's Avatar
Aaron-74
Default Re: How much HP difference do mufflers make? (Aaron-74)
http://www.aaron74.homeip.net:81/Sound/beast.wav
what they sould like.
Old Mar 6, 2002 | 11:39 AM
damac's Avatar
damac
Aaron-74,
I am glad I am not your neighbor.
Those pipes must be pretty loud.
Mike
Old Mar 6, 2002 | 12:02 PM
Aaron-74's Avatar
Aaron-74
There going to be REALLY REALLY loud. But, I am planning on having an H-pipe some where on the system. I don't know if I want to do it closer to the headers and get more power, or closer to the tips and soften it down a little bit.
Old Mar 6, 2002 | 03:41 PM
Top_Notch's Avatar
Top_Notch
Aaron...sounds good.
Old Mar 9, 2002 | 07:18 PM
63Banshee's Avatar
63Banshee
From: WANTED: '68 rear valance with b/u light assemblies IM, e-mail, or PM me here. Thanks!
I highly recommend Ultra Flo muffs!
To How much HP difference do mufflers make?
