Has anyone easily accomplished this task or have any quick tips?
All of the instrumental is weak at best and flickers with rotating the switch assembly, so hopefully replacing will give some much needed improved lighting to the gauges.
From looking at the Haynes manual it looks like you have to pull out the Gauge Cluster and access from there, so is that really necessary or can you get it done easily from below with the vent duct moved ?
Easy task or pain in the a** and busted knuckles ?
You do NOT have to remove the gauge cluster to replace the headlight switch on an '81. I've removed and reinstalled the switch on my '80 several times from below. It helps to remove the seat first so you can get your arm up there. Unless you have a power seat, you just need to remove 4 bolts to take the drivers seat out.
The most difficult task is to remove the **** and shaft from the switch. The shaft is held into the switch by a spring loaded button on top of the switch.
Push the button in all the way to release the shaft. The shaft/**** will just pull out once it is released. If you can find a picture of the shaft, you will see a grove near the end of the shaft. That's what the spring loaded button hangs onto to keep the shaft/**** in the switch.
Once the shaft/**** are out, I used a screwdriver to unscrew the retainer ring that holds the switch to the dash. The switch will drop down and you can remove the vacuum lines and connector.
I'm gonna respectfully disagree with which method is easier. I can have an 81 Cluster out and the headlight switch in my hand in less time then getting the 4 seat bolts out and trying to reach up under the dash and get the connector disengaged from the switch.
With the cluster out you can also test and check both the switch, bulbs, circuit, etc. to see what the problem really is (do all the lights work?). Also note that the new replacement switches are junk. At least the ones that I have gotten from major vendors. I'd get a good used one from a boneyard but you probably can just clean up what you have and reuse it.
Do whichever method you are more comfortable with. Both ways will work. But if you put it back together and still have a problem you will end up having to pull the cluster anyway.
Unless you have 1st grader size hands, I've always pulled the inst cluster to get the headlight switch out - MUCH more access, BUT i wear XXL size gloves............................
YRMV
There is probably better access with the cluster out and some people have no probems taking the cluster out. I take the drivers seat out routinely because I hate trying to work on anything under the dash with the seat still in. When you take out the seat as many times as I have, you get good at it - 1 minute tops with an air wrench and extensions. The only times I removed the headlight switch was when I had other things to do under there. The only time I had the cluster out was a bad experience.
All the Lights/Guages work perfectly, just doesnt seem bright enough by modern day standards.
The rotating dimmer **** on the switch is touchy and nervous at best when turned so I figured the copper? is worn and a fresh switch may restore all power.
The switch was the new improved Hvy Dty version from major Ad vendor and was hopefully superior to OEM version?
You CAN disassemble the switches and clean them up. I did that with the one on my 80, and it was night and day difference....no pun intended! A fair amount of contact cleaner will also help. I saved a bunch of money on doing that myself, and I'm not sure that most C3 owners are aware you CAN clean them up and reuse them. Same goes for the wiper switches.
And if you want brighter gauge lights, upgrade to a different bulb, even the small LED's will make a huge difference. A different set of headlamps will also greatly improve your night vision. Easy to do for the most part. Maybe not CHEAP, but easy nonetheless. Good luck!
I've tried removing the switch using both methods mentioned. You do have more room with the cluster removed and it not that much work. The worse part of reaching up from underneath is getting the switch connect off and back on, but it can be done......Tim
I found removing the phillips head screws on the left side of the dash pad near the A-pillar and pulling the pad forward a bit makes pulling the switch much easier.
