Fully Synthetic Oils ??
And what about the virtues of Synthetic over Convential ? Are they worth it?
My cars range from
Chevy Tahoe takes 5w-30
Sanger Ski Boat takes 10w-30
Ford V10 RV takes 5w-20
Corvette has 10w-30 Synthetic
So is Synthetic worth the price and can I just put 5w-20 in everything with no issues at all ? or should I just keep investing in the oil cartels and buy a different case of all ?
{OK...now let the 'fun' begin.}
List of Flat-Tappet Oils
But a synthetic is definitely what you want across the board.
I would use at least a 10W-40 in the vette and make sure it has enough zinc. (Amsoil AMO 10W-40 is great) if you choose to use a synthetic.
As for your individual applications, they really do all take different oils optimized for that application. Your Tahoe is going to require a modern API SM 5w30 which the API mandates a limit of 800 ppm phosphorus (key anti-wear additive), your boat will require a marine motor oil which has high levels of anti-wear additives along with anti-corrosion additives not found in automotive oils, Ford specs 20 grade oils to help with their cafe so you'd have to go against owner's manual requirements to use the same 5w30 you use in the Tahoe, and the Corvette should use a high ZDDP oil as mentioned above (and you're going to have a tough time finding one off the shelf).
I'm in a similar situation and as a result, stock a lot of oil - one of the reasons I ended up becoming a dealer. I race my 02 Z06 and use race oil, use 5w30 in my Trailblazer, CJ-4 diesel oil in my GMC 3500 HD tow vehicle and CI-4+ diesel oil (higher anti-wear additives than CJ-4) in my RV.
All synthetics are not equal. The API has not come out and defined what is "synthetic", but rather, classified oils into five major groups.
Group I base oils are the least refined of all of the groups. They are usually a mix of different hydrocarbon chains with little or no uniformity. While some automotive oils use these stocks, they are generally used in less demanding applications.
Group II base oils are common in mineral based motor oils. They have fair to good performance in the areas of volatility, oxidation stability, wear prevention and flash/fire points. They have only fair performance in areas such as pour point and cold crank viscosity. Group II base stocks are what the majority of engine oils are made from. 3000 mile oil changes are the norm.
Group III base oils are subjected to the highest level of refining of all the mineral oil stocks. Although not chemically engineered, they offer improved performance in a wide range of areas as well as good molecular uniformity and stability. By definition they are considered a synthesized material and can be used in the production of synthetic and semi-synthetic lubricants. Group III is used in the vast majority of full synthetics or synthetic blends. They are superior to group I and II oils but still have limitations. Some formulations are designed for extended oil changes. AMSOIL XL Motor Oils, Castrol Syntec and many others fall into this category.
Group IV are polyalphaolefins (PAO) which are a chemically engineered synthesized basestocks. PAOs offer excellent stability, molecular uniformity and performance over a wide range of lubricating properties. AMSOIL SAE Synthetic Motor Oils and Mobil 1 primarily use group IV basestocks (though recent info posted on the oil forum indicates that Mobil 1 is also now using a significant proportion of Group III basestock). PAO is a much more expensive basestock than the highly refined petroleum oil basestock of Group III.
Group V base oils are also chemically engineered stocks that do not fall into any of the categories previously mentioned. Typical examples of group V stocks are Esters, polyglycols and silicone. Red Line uses an ester basestock.
In the 90s, Mobil filed suit against Castrol for falsely advertising Syntec oil as synthetic, when in fact it contained a Group III, highly hydroprocessed mineral (Dino) oil, instead of a chemically synthesized (group IV or V) basestock. Due to the amount that the mineral oil had been chemically changed, the judge decided in Castrol's favor. As a result, any oil containing this highly hydroprocessed mineral (Dino) oil (currently called Group III basestock by the American Petroleum Institute) can be marketed as a synthetic oil. Since the original synthetic basestock (polyalphaolefin or PAO) is much more expensive than the Group III basestock, most of the oil blenders switched to the Group III basestock, which significantly increased their profit margins.
C66 Racing #66 NASA ST2, SCCA T2
AMSOIL Dealer (Forum Vendor)
AMSOIL Preferred Customer Program (Members buy at Wholesale - a savings of about 25%)
We do use synthetic in my dad's 90 ZR-1, my 98 camaro, dad's 01 5.3L suburban, and my 01 5.3L silverado. Unless you have a high tolerance engine, the synthetic isn't needed and conventional will work just fine in older engines.
For comparison, here's a link to Mobil's current listing of phosphorus/zinc in their whole product line. Best bet is their 0w40 which is 1000/1100 in my opinion as I personally feel that their 15w50 has too high a viscosity for most street applications.
http://www.mobiloil.com/USA-English/...duct_Guide.pdf
