68 rear compartments
Old Jan 25, 2010 | 10:12 AM
Toms-68's Avatar
Toms-68
Default 68 rear compartments
Hello guy's, I need info on the door straps or bezels with lifting flange to assist opening the three compartment doors? does anyone know what is correct for the rear compartments or was 68 plain with just the bezzel?
Tom
Old Jan 25, 2010 | 10:27 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
I'm thinking the '68s did not have the loops and the metal loop bezels were way later. '68 AIM will show them if they were used.
I installed the metal loop bezels on my '68.
Old Jan 25, 2010 | 12:27 PM
DZRick's Avatar
DZRick
I'll be damned!
Mike is correct, the '68 AIM shows no strap or metal loop. I always thought that the '68 used the straps and '69up used the metal loops, now can someone tell me how it was possible to lift the lids?
Old Jan 25, 2010 | 02:06 PM
Easy Mike's Avatar
Easy Mike
Originally Posted by DZRick
...can someone tell me how it was possible to lift the lids?...
With difficulty.
Old Jan 25, 2010 | 03:39 PM
DZRick's Avatar
DZRick
With difficulty.
Now I understand all those guys saying the '69 is better than the '68.
Old Jan 25, 2010 | 03:51 PM
Alan 71's Avatar
Alan 71
I believe the vinyl pull straps were added in mid 69 production.
What's interesting is that there was a Technical Service Bulletin to the dealers instructing them to install the straps on 68s and early 69s IF the customer COMPLAINED.
Regards,
Alan
Old Jan 25, 2010 | 05:21 PM
DZRick's Avatar
DZRick
Regards,
Alan
In that case, I'm going to the dealer tomorrow.
What the hell were they thinking not putting something to grab onto?
Old Jan 26, 2010 | 09:46 AM
Toms-68's Avatar
Toms-68
Thanks guy's...........So if I add the strap it would be correct Now my car is worth as much as a 69 I will sell in the spring, watch the classified's.
Tom
Old Jan 27, 2010 | 10:14 AM
Budman68's Avatar
Budman68
Cruise-In VII Veteran
St. Jude Donor '07
Mine have the original spring hinges and no loops. I ended up removing the hinges and selling them, because it was almost impossible to get them to line up and not strip out the metal support behind the fiberglass. Very poor design, so forgive me NCRS guys for changing them out.
Old Jan 27, 2010 | 10:17 AM
Budman68's Avatar
Budman68
St. Jude Donor '07
FYI - The correct hinges will have a metal loop at the end of the hinge pivot at when closed acts like a spring under tension to pop them open. Another cool 68 only item.
Old Jan 27, 2010 | 04:25 PM
DZRick's Avatar
DZRick
I've got the hinges from my parts car, I knew I had heard that they were unique but couldn't remember what it was. Thanks.
To 68 rear compartments
