Starter problems
Old Jan 26, 2010 | 08:00 PM
Attfay Elleybay's Avatar
Attfay Elleybay
Default Starter problems
I replaced my starter last week. It's been fine until today. It would make a grinding noise when I tried to start it. After about 5 tries (20 to 30 seconds apart) it started fine. Any ideas?
Old Jan 26, 2010 | 08:01 PM
thoyer's Avatar
thoyer
Bolts are coming loose?
Old Jan 27, 2010 | 03:32 AM
mydejavooo's Avatar
mydejavooo
Sounds like the bolts may have backed themselves out a bit, or you might have a shimming issue. Kind of weird that it waited 5 days to start doing that, and that's what also makes me think its the bolts that are doing that. Let us know what you find out.
Old Jan 27, 2010 | 04:38 AM
71406's Avatar
71406
Not sure what kind of starter you used, but did you use bolts designed for a starter? When I switched to a mini-starter I needed to get new bolts from GM.
Old Jan 27, 2010 | 04:44 PM
69Vett's Avatar
69Vett
Corvette of the Year Winner 2017
2016 C3 of Year Finalist
Did you check the starter pionon gear clearance when you installed it ?
Did you use actual starter bolts, to prevent the starter from shifting ?
did you intall the orginal brace for the starter ?
69VETT
Old Jan 27, 2010 | 05:41 PM
Attfay Elleybay
It was a direct replacement starter. I used starter bolts. It hasn't done it since
Old Jan 28, 2010 | 10:40 PM
79vette383's Avatar
79vette383
Cruising
Sounds like a shimming problem....or bolt issue.....put some locktite on the bolts and check the clearance I had the same issue when i bought my car...the guy that had it before didnt do anything about it...the starter whinned really bad and i shimmed it out a bit and it fixed the problem
To Starter problems
