Pilot Bushing Trick -- Useful!
I always start with the grease trick.. and then escalate my assault according to resistance... with the tap/bolt being my last resort. Mustang 302's are tempermental in this way... at least most of the ones I have done.
--- and I agree about the newer LS engines... DONT USE THIS METHOD! The pressure P will force the freeze plug out and then you are really screwed. -- Take the time to tap it and get a slide hammer out and youll be fine!
The comment about getting the tolerance tight between the dowel and the worn out bearing is on the money. Unfortunately, worn pilot bearings aren't going to fall within the desired tolerance... they will all be worn differently... and a new dowel would have to be made for nearly every one you pull.
It's gonna work... but not always.
I tried half a dozen different Muncie shafts as well as chicken legs, donky dorks, and metal mushrooms on this last one. None of them provided a tight enough seal to confine the hydraulic pressure. That's when I tried the pullers (yes... I have the one that the auto parts stores rent out... I bought a new one in a pretty plastic case just for this project and it didn't work).
I think if you get the seal tight enough -every time- it will work... but that's the trick.
After several hours screwing around with various dowels and pullers, I gave up and went for the tap/bolt and slide hammer.
I wanted to measure the wear on the old bushing and tapping it ruined all my chances of doing that... so I didn't rush into it.
One other tip I can add is if the dowel is slightly loose in the bushing, cut a 1" wide strip of paper and wrap it around the dowel, or whatever your using, until the dowel has a tight fit...tight enough that it requires a tap with a small hammer to get it in....then get out the big hammer and give it a good solid whack.....it'll pop right out. I've used this method several times
I use duct tape instead of paper. The tape seals better IMO as duct tape is a bit compressible.
to everyone else Im just saying that that method should be secondary to the hydraulic method which is the cheaper/faster/easier way to do it. And it really isn't that messy like everyone keeps complaining about... i just was a noob the first time i did it and had too small of a dowel but it still worked in addition to ruining a shirt. Using my machined brass dowel i dont even need a shop rag around the rod, there is no grease splashback because the seal is so tight. Once the bearing is out... wrap a rag around your dowel and swipe out the excess grease, you dont even really need to get it all. Excess grease in the bushing will only help it function that much smoother when your crank and input shaft are spinning at 6000 rpm!
pack with grease , insert input shaft and smack it good a couple times.
I have removed many over the years this way, this is the way most older mechanics did it,
they didn't have a rent it tool shop around the corner. 69VETT
I didn't say I would "reuse" the old bushing. Sometimes being able to remove a bushing without further damage for inspection provides useful information. I would think being an engineer you would understand this.Raider, the tool in Topgunn's pic is "exactly" like mine, 2 seconds with my 1/2" impact and the bushing is out. You wouldn't even have 1 of your latex gloves on in that time.
My mis assumption my good sir. As far as the impact wrench method that is far too involved. When my motor is on my motor stand I dont even get my gun near it. It is all hand tools, so I can feel the work on the engine, and I think it takes me less than two seconds. I have the hammer in my right, the rod in my left, swish it in the grease, put it in the hole, and smack it... feasibly takes about one second. no air lines to drag over or compressor to fill up, no crazy bolt to modify, no socket to go get, and saves the bushing every time! Plus for extra wrenchin style a good mechanic will grease the pilot bushing anyways to lubricate when the engine and tranny are mated again. This way automatically does that, because when you install the new bushing the grease re-locates to the center! Why not save yourself the hassle of having to deal with air tools AND get the grease?
Imagine a crankshaft when going through inspection that is found to be perfect except the pilot bushing hole....
...hmmm.....Install it in an engine with an automatic trans because the nose of the torque converter doesn't require as close a tolerance as the 4 speed input shaft.I have seen the pilot bushing hole machined too large,too small and the what most guys miss,the machined part of the hole is too short,shallow,not deep enough. This lack of depth on the machined surface can cause the the ID of the pilot bushing to be made smaller if the bushing is driven in too far. This will cause the input shaft to fit too tight and cause grinding when going into gear.
The moral to the story is don't forget to inspect the pilot bushing hole before building your engine around the crank. ( Also don't forget to check the flywheel flange for runout.)
I've seen this overlooked area of the crankshaft RUIN many a guys day.
maybe
I think they needed it in there to balance the assembly too. I am not sure about this because I was not there, all I know is there was a non roller bearing in there when I went to pick up my rotating assembly after balancing
The shop has probably changed or replaced a few thousand over 30 years. No, they aren't a mickey mouse shop they build the motors for the TV show ( don't even know if that show is still on ? ) Dream Car Garage and build the big block rats for Peter Klutts' '69 Corvette vintage road race car. Like I said they know every trick in the book.
Most of the methods used in this thread have been used how many times ? Once, twice maybe 10 times or more ? by each individual member. Saying something will work in every case is like saying you have the fastest car in town, and we all know what happens there
I tried this method once a few years back and it didn't work for me. I also broke the loaner puller and eventually had to grind / drill / chip it out.
The tool didn't break when trying to pull the bearing, it broke when I threw it down the driveway after it wouldn't catch the back of bearing
Theoretically the grease method would work every time on bearing that was not in there too tight. I might even say hitting it with enough force might dislodge a very tight bearing but you are not going to be able to create that much force with your arm.
The method you describe will work but not in all cases, I can also see that the bolt method would work but might not in every case too. The bolt threading in would expand the bearing creating more friction on the bearing to crank surfaces and I can see it just turning and making stripped threads and the bearing not moving.
Please don't get me wrong here I am not trying to put down anyone's ideas, on the contrary the grease method should be at least tried first, then maybe a puller, then maybe you can make one of those bolts and you will have success without resorting to grinding it out.
Everyone is trying to help here and lots of good ideas so use whatever method works for you
