bad heat core?
Old Jan 28, 2010 | 05:12 PM
ripforrey's Avatar
ripforrey
Default bad heat core?
On 76, 350/auto w/ ac.
The body shop that installed w/s did a poor job and after 2 wks. of rain I have damp drivers seat and damp carpet on both sides on floor board.
I noticed the coolant level in radiator was down a little (recovery tank empty as well)so I'm thinking I have a bad heater core as well. Installed a new core, hoses, and water valve last year. Everthing checked out ok after install and worked fine up until now.
Ideas on how to check, by pass heater core without taking everthing apart would be apprecaited.
Old Jan 28, 2010 | 07:21 PM
nitrocharger's Avatar
nitrocharger
The heater core isnt the only place coolant can become lost. One hose will be 5/8" and the other 3/4". You can connect the two with the right pipe adapters although the leaking weatherstripping would be more alarming to me. If you let water get into your birdcage area it will rust out quicker than Obama says the word "transparency"!
Old Jan 29, 2010 | 09:50 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Do you smell antifreeze on the passenger's side? Driver's seat being wet would not have anything to do with the heater core.
Old Jan 29, 2010 | 11:47 AM
joewill's Avatar
joewill
I always do the taste test.. easy to tell if antifreeze...
Old Jan 29, 2010 | 12:09 PM
ripforrey's Avatar
ripforrey
Default heat core
I don't smell a-freeze on pass side but, I have a hard time smelling a-freeze. I'm going to tie the 5/8" X 3/4" hoses that go into core and see if that solves part of the problem.
Thanks for the thoughts.
Old Jan 29, 2010 | 12:22 PM
Paul L's Avatar
Paul L
Before going to that trouble, just dip a piece of paper towel into the carpet on the passenger side. If it comes up green...heater core.
Old Jan 29, 2010 | 01:12 PM
Easy Mike's Avatar
Easy Mike
Originally Posted by joewill
...I always do the taste test...
I let the neighbor's dog do that.
To bad heat core?
