cooling lines
Old Jan 28, 2010 | 05:38 PM
xemilliox's Avatar
xemilliox
Default cooling lines
does anyone know which cooling lines run to which port on the transmission? I have a 78 which had a th350 in it but I swapped it out to a 700r4. Thanks
Old Jan 29, 2010 | 10:01 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Probably doesn't make much difference. All you're doing is routing tranny fluid through the radiator for cooling purposes and back to the trans.
