swing arm
Old Jan 31, 2010 | 07:12 PM
Carl D's Avatar
Carl D
Default swing arm
How do you remove rusted seized swing arm bolt?
Old Jan 31, 2010 | 07:14 PM
Gordonm's Avatar
Gordonm
Sawzall. Search this topic. You will find many posts on this.
Old Feb 2, 2010 | 06:54 PM
Carl D's Avatar
Carl D
Yes trie saw zal since blade is not made out of carbide it is difficult to cut thru hardened bolt
Old Feb 2, 2010 | 07:35 PM
Gordonm's Avatar
Gordonm
I answered in the other post but get yourself a GOOD bimetal blade. I have worked for Lenox for 25 years and have access to all kinds of blades. I have done both trailing arms with one blade quite easily. A 18 or 14 tooth blade with a little cutting oil will get the job done. You don't want a carbide tooth blade, they will chip and break. A carbide grit blade will work but is very slow cutting.
To swing arm
