NO More Stuck Hoods.
Old Feb 1, 2010 | 06:27 PM
1976 corvette's Avatar
1976 corvette
Default NO More Stuck Hoods.
When I was doing an engine bay restoration on my 76 vette, the hood became stuck once I tried to reinstall it. This was a pain to get loose. I went to the forum for help and came up with many different ways to get it loose from cutting the hood to jumping on it. I later found a thread saying to reach your arm through the control arm openings and loosen the bolts on the hood. Even though this worked, it still took around 3 hours to get free. When I went to reset it for the second time I wanted to be sure that I could get it free again so I made this. It is a manual way to open the hood in the case of the hood release isn’t working or it breaks. Now the security part of it is that the only way to reach the release is to turn the wheal to full left or else it can't be touched. Hope this can help someone.
Old Feb 1, 2010 | 06:40 PM
Artsvette73's Avatar
Artsvette73
I like it
Old Feb 1, 2010 | 06:44 PM
MN80Vette's Avatar
MN80Vette
A lot of C3 owners are going to save this idea. I was going to drop some cables down from each latch, but this idea doesn't have any dangling cables.
Old Feb 1, 2010 | 06:58 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
I've got them on both sides, very thin mechanics wire but strong you don't even see them and I have tested it out. Been there for tens years or since the first time I locked myself out
The OP's method is very nice
Old Feb 1, 2010 | 08:29 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
looks good i like the idea
Old Feb 1, 2010 | 08:33 PM
71coupe454's Avatar
71coupe454
I didnt know this was a problem.. is it all years? my hood has not been on mine much since I have had the car..
Old Feb 1, 2010 | 08:44 PM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
Great idea. I was thinking of doing something like Motorhead has done. May have to borrow this idea one of these days. Wonder if you could sell this to Mid America or some of those guys. Nice work.
Old Feb 1, 2010 | 09:41 PM
MN-Brent's Avatar
MN-Brent
Fantastic solution. Probably the best I've seen for this problem. I might have to borrow this idea as well-someday
Old Feb 2, 2010 | 01:17 AM
JohnRR's Avatar
JohnRR
Great idea, thanks for sharing!
Old Feb 2, 2010 | 11:45 AM
SH-60B's Avatar
SH-60B
Nice work.
Old Feb 2, 2010 | 09:44 PM
aussiejohn's Avatar
aussiejohn
Default Stolen!!!!
Kevin,
Consider your idea "stolen" and it's heading Down Under. That's what I love about this Forum, a private Corvette owner invents something that the big Corvette vendors should have had on sale decades ago. Full marks to you for this.
Regards from Down Under
aussiejohn
Old Feb 2, 2010 | 09:51 PM
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
You should get a gold star and a smiley face.
Old Feb 2, 2010 | 09:54 PM
jordan89's Avatar
jordan89
That's a great idea. I'm going to have to do that to my Vette.
Old Feb 3, 2010 | 02:11 AM
thegavel's Avatar
thegavel
Originally Posted by aussiejohn
Kevin,
aussiejohn
Yep, I'm gonna do it too.
Well Done.
from Down Under.
Gav
Old Feb 3, 2010 | 02:47 AM
73StreetRace's Avatar
73StreetRace
Clean and efficient. I like the idea. Thanks !
Old Feb 3, 2010 | 06:53 AM
MrJlr's Avatar
MrJlr
Sweet.....you got my vote for "Best Solution" !!!!!
Old Feb 3, 2010 | 09:35 AM
shmoky's Avatar
shmoky
Copied and saved. GREAT idea and very efficient.
shmoky
To NO More Stuck Hoods.
Old Feb 3, 2010 | 01:16 PM
76GlassY's Avatar
76GlassY
I believe it was mentioned on this forum once before, but if you look on the firewall area to the drivers side of the hood latch pin/spring assembly (driver and passanger side), you'll see plastic plugs that cover holes that lead into the wiper area, one on each side. With the hood latched closed, if you go in from the wiper area, drivers side, and pop that plug out you can get a screwdriver in there to push on the drivers side latch piece (the piece that has the 90 deg bent "tang" pointing down, directly across from where you welded the extension on to hook the rod). If the cable is still connected to the passenger side, it should open both latches. The passenger side doesn't have that "tang" on it but I think you should be able to move that latch piece towards the drivers side with a screwdriver (thru the popped plug on the passenger side) to open that latch if the cable connecting the two sides isn't doing its job. Looks like the factory foresaw this problem and put the access plugs in there for this exact reason. I'm sure if you search this forum you'll find the original post and who posted it. I read it, went and looked at mine (also a 76) and saw what he was talking about... and have wanted to thank him since, because I'm sure one day Murphys Law is going to rule (again) and I'm going to have to pop the hood that way.
Old Feb 3, 2010 | 03:51 PM
Alan 71's Avatar
Alan 71
Will this fix help SHUWANG and make his search for a fuse list for his 99 BOXSTER unnecessary?
Regards,
Alan
His thread is named... Where can I find a wiring diagram.
Old Feb 3, 2010 | 08:02 PM
DM76's Avatar
DM76
Nice........... two thumbs up.
