top end replacement or repaint first
Old Feb 4, 2010 | 03:38 PM
merrell.a's Avatar
merrell.a
Default top end replacement or repaint first
Was going to repaint my 81 then replace my heads and cam shaft. But now I am thinking I should do the top end replacement prior to repainting? Any thoughts/recommendations.
Old Feb 4, 2010 | 03:56 PM
Alan 71's Avatar
Alan 71
Hi M,
I believe I'd do the mechanical work first, make sure everthing is operating the way you want, and then do the paint work.
Regards,
Alan
Old Feb 4, 2010 | 06:02 PM
gr8vet's Avatar
gr8vet
St. Jude Donor '06
Repaint, people can see that. Lie about the rest, no one will ever know.
Old Feb 4, 2010 | 06:06 PM
nate99's Avatar
nate99
Depends on how ugly the paint looks now.
I needed both (engine leaking everywhere, paint ultra chitty) and I did the engine first. I wanted a driver first and then a good looking driver. If the car was running without any issue, I may have gone the other way.
Old Feb 4, 2010 | 08:00 PM
jordan89's Avatar
jordan89
Mechanical work first!! That's what I did to my 78 Camaro. I don't care what it looks like I did my mechanical work first, and it has two different color layers of primer, and some of the original paint.
Old Feb 4, 2010 | 11:16 PM
DRIVESHAFT's Avatar
DRIVESHAFT
The more time you spend leaning over freshly painted fenders, the more likely you are to scratch that pretty new paint.
If you know that you intend to do both, do the engine work first.
Old Feb 5, 2010 | 04:20 AM
merrell.a's Avatar
merrell.a
That exactly what I was thinking, thanks gentleman. gonna get my heads and cam tomorrow.
Old Feb 5, 2010 | 12:31 PM
wayne3434's Avatar
wayne3434
4th Gear
Is it the stock motor? If so what heads and cam are you going with.
Old Feb 5, 2010 | 01:01 PM
OMF's Avatar
OMF
DO THE MECHANICAL FIRST......yes I'm yelling. It dosn't matter how hard you try the paint will get scratched or chipped doing that kind of work, and you won't feel good about it when it happens
To top end replacement or repaint first
