Spreader Bar
Old Feb 5, 2010 | 12:13 PM
81pilot's Avatar
81pilot
Default Spreader Bar
I read all I could find on using a spreader bar, and in all of them, nobody is using an engine driven fan. I know there is one you can buy to position and weld the tabs on, that is supposed to clear the fan and water pump, has anyone added one and left the fan on? Or will my stock 81 fans on my close to stock motor keep it cool enough without the clutch fan?? I have had a little cracking and want to keep it from happening again. Thanks
Old Feb 5, 2010 | 12:46 PM
78IndyPace's Avatar
78IndyPace
Default Unwelded Spreader Bar
Installed one last summer. Had to fab taller end plates as the ones supplied did not have sufficient material for a good weld with the spreader bar clearing below the stock engine driven fan pulley's "bell". Used 2" wide bar stock in place of the 1" end plates provided. Not difficult, but a PITA given the price. Had to taper the rear of the plate on the passenger's side to clear the radiator hose, too.
Was it worth it? My car is a very low mileage machine in excellent condition with no spring tower cracks. After installing the spreader bar, I think it's a bit stiffer in front, but not a whole lot. And I drive it hard on very winding mountain roads. Since you've had cracking you may feel more stiffening with the spreader bar. On mine, I would not do it again given the end plate fabrication I had to do to make it fit.
Hope this helps.
Jerry
Old Feb 5, 2010 | 01:09 PM
682XLR8's Avatar
682XLR8
I installed the VBP weld-in bar, and also had to fab my own mounts from 2" bar stock, clears just fine
Old Feb 5, 2010 | 02:56 PM
81pilot's Avatar
81pilot
Thanks guys, just the info I was wanting, I am a decent welder and fabricator, so I guess I will order one up! If nothing else it will give me some piece of mind.
Old Feb 5, 2010 | 03:19 PM
78IndyPace's Avatar
78IndyPace
Since you are a fabricator & welder, you might want to save a few bucks and make yours from scratch. Here's a link:
http://forums.corvetteforum.com/c3-t...stock-fan.html
Lots more info out there. Do a search.
Old Feb 5, 2010 | 03:23 PM
SIXFOOTER's Avatar
SIXFOOTER
If you have the skills just build it. These guys have pretty good prices on bits and pieces
http://www.qscomponents.com/
Old Feb 5, 2010 | 03:52 PM
81pilot's Avatar
81pilot
I may just do that, I was actually thinking about a gussett on the front lower cross member and going down from each side to that which has a flat bar linking the two, with torsion adjusters from there, it would have the same load rating and work just as well from what I have figured. Thanks!
Old Feb 6, 2010 | 09:50 AM
c69vete's Avatar
c69vete
Finalist 2021 C3 of the Year - Modified
2017 C3 of Year Finalist
Cruise-In VIII Veteran
St. Jude Donor '07
It was my experience that when you purchace the commercial parts as a kit, the mounting bar that attaches to the A-arm bolts is only 1" wide. On my car I had to use a 2" flat bar to get the bar under the fan pulley.
I used a piece of 3/4 in PCV pipe to mock up what I needed to make things fit.
Good luck with your project as I'm sure you will feel and like the improvement.
To Spreader Bar
