i've been trying to do my own alignement and have read the numerous threads on the forum but i have come across a dilemma.
as you can see from the photo, camber has been set. 3 shims at each end of the a-arm. i have 0°
camber.
now i have to set the castor. to add positive castor i normally have to add shims to the rear
of the a-arm in order not to change the camber. am i right? i'm running out of thread on the
a-arm bolts.
or can i take a shim of the front position to add positive castor? will the camber i set before
change in this case?
thanks
Castor is oil, caster is lean from an axis. To change caster and not disturb camber you add or subtract the same amount of shims to the front or the rear. If you add to the front, take the same out of the rear.
Adjust the caster first and then the camber. Caster adjustments are done by removing or adding shims to the front or the rear studs. Once the caster is set (equal as possible on both sides) then you can work on adding equal thickness shims to both studs to adjust the camber. After each change you make, drive the car to settle the suspension and recheck before moving on. Check out the VetteBrakes web site for goby alignment specs.
so which adjustment should i do first -- camber? castor?
It don't really make any difference. You will need to recheck each time you make a change anyway, and eventually they both will have to be correct at the same time.
I ran across the same issue with my 69. I had so many shims, you could not get the bolt on. But I Time Trial the car and ran more camber an a street driven car might.
As I see it, you have two solutions.
1) Bang out the Corvette stud and replace it with longer studs. A friend did this and used heavy duty racing wheel studs.
2) I went with Guldstrand Steel offset upper control arm bushings. They are drilled eccentricly so major adjustments can be made by turning the bushings and fine adjustments with a minimum of shims.
they also make an offset shaft.uses the stock bushings.Set the camber first.once thats set,move shims from front to back or visa versa.the camber will stay the same or very close to it.Once the car drives straight with the desired castor,check the camber again.castor has the most effect of pull to one side or the other.amber can also make the car pull but not as much.Then set the toe and center the steering wheel.
I still say Castor is a bean from which Castor oil is made. Caster is what we are talking about.
My understanding is to steer the car +20 deg, take camber reading, steer -20 deg and take camber reading. Subtract the numbers and multiply by 1.5. This is your caster in degrees.
My car: about .5 deg positive at +20, about 2.25 deg positive at -20 deg. So my caster was (2.25-0.5)*1.5 = 2.626 deg. (my car had an major positive camber and a lot of toe in - the caster value was the only number even remotely close to the correct setting).
there is a hot rod article where i got this method from.
