#$%! Front Bumper Nuts !!!
Old Feb 9, 2010 | 03:04 PM
Rmorgan&11's Avatar
Rmorgan&11
Default #$%! Front Bumper Nuts !!!
Any trick to getting to these retainer nuts @ the corners of the '76 Front Bumper ???
Damn near thrown my whole tool box at them and still can't get on them fully to remove them !!!!!
and this is just the retaining strips ...the bumper has already cracked off !!
Old Feb 9, 2010 | 03:20 PM
ikwhite's Avatar
ikwhite
I seem to remember having to use a small dremel/die grinder with a burr bit to grind off the last of my stubborn 77 rusted out corner retainer nuts off , perhaps that might help you as well.
ikwhite
Old Feb 9, 2010 | 03:38 PM
Rmorgan&11's Avatar
Rmorgan&11
I can't even get a socket on them and can barely get my hand in there to touch them !!
Old Feb 9, 2010 | 04:11 PM
Duke94's Avatar
Duke94
I feel your pain. I think I used a small skinny nose vise grip plier to hold the nut. Also applied lots of PB Blaster. Good luck
Gary
Old Feb 9, 2010 | 04:15 PM
wcsinx's Avatar
wcsinx
Probably not the answer you want to hear, but I've heard of guys cutting access holes through the inner fenders to get at those fasteners.
I dread tackling this job.
Old Feb 9, 2010 | 04:52 PM
blckslvr79's Avatar
blckslvr79
Just removed my bumper cover this weekend. Couldn't get to them either. I cut access holes in the old rubber bumper with my dremel and ground the heads off the bolts. Worked great.
Now if your trying to save the bumper.....
Old Feb 9, 2010 | 05:04 PM
Rmorgan&11's Avatar
Rmorgan&11
Bumper was trashed and dry rotted already, actually all that was left under the Bra was the license plate holder & front 2 center Pods ! I cut them out with a die grinder and ordered new retainers......now to figure out how I'm gonna get the new ones Tight when they get here ???
Bumper retainers finally off >
Only part of bumper that was still on car under bra cover when I started
Old Feb 9, 2010 | 05:15 PM
dobroman2001's Avatar
dobroman2001
I had the side marker lights out and could (but still just barely) get a socket on those nuts.. I used a 1/4 driver with 8 inch extension. I had the driver outside the the marker light hole. Hope that makes sense
Old Feb 9, 2010 | 05:19 PM
Rmorgan&11's Avatar
Rmorgan&11
thanks !
To #$%! Front Bumper Nuts !!!
