Carb sizing & engine rebuild.....
Did I just buy way to big a CFM carb?
When I started planning the top end rebuild (my plan here
http://forums.corvetteforum.com/c3-tech-performance/2424114-engine-build-)up-feedback-fall-edition-long.html
I did some research, read a bunch of magazine articles and noticed that without fail 383 builds used a 750 cfm. Ryans Car Page even summarizes a lot of these builds:
http://www.ryanscarpage.50megs.com/combos1.html
So when I needed a new carb a year ago, I went ahead and bought the speed demon 750. On the current / old engine build, this was def too much carb but will it work on the new configuration? Or am I still oversized? I know the volume calculations say yes but I am hoping with the more aggressive cam and higher flowing heads I will be more in line with the capabilities of the carb. My hope is, at worst, I simply sacrificing throttle response.
Trying not to add to the already blown out of the water budget I put together for the rebuild so hoping I can make this carb work for the new set-up.
Thoughts / feedback?
Shane
Hope this helps...
As a test, I went through the Holley Carb Selector on their web site and it actually recommended a 750cfm 4150 (part #82751).
Everything I hear is BG is good but the ore I read and learn it sounds like the Holey is just superior from an ease standpoint.
Shane
V8FastCars@msn.com
I run 750's on performance engines over 302 CI with no problems. It's all in the tuning.
I run a lot of different carbs and carb sizes on my test engine (357 smallblock with heads and a cam). I've run carbs as big as 1050 on this engine with no problems at all if the carb is set up right. Here's the deal: A small carb will be easy to tune, because it will run "OK", even with a lot of tuning problems. A "right sized" carb needs to be set up right, which most people can't do. An "oversized" carb will not give you any more horsepower, but it will not be your limiting factor. An "oversized" carb will run just fine if it is properly tuned on a smaller engine. I run 1050 and 850 carbs on my small blocks with no problems at all. I don't advocate this for the average street car, but I make the point: A carb that's "too big" is probably not your real problem when it comes to tuning - it's the overall setup and state of tune of your engine and carb. If you don't know what you're doing, get a small carb. If you understand carb setup and tuning principles, err on the big side.
I'm going on the dyno with a small block next week. I have 2 carbs to run on it: a 750 and an 850. I won't be running a 650/670. I'll post the results...
Lars
V8FastCars@msn.com
You do not "jet down" a bigger carb to run right on a smaller engine. In fact, a big carb installed on a small engine receives less of a metering signal than a smaller carb, so it actually runs lean. You need to richen up a big carb on a smaller engine - not lean it out. If you lean out a big carb on a small engine, it will run like crap, thus the bad name for the big carb/small engine combo.
Lars
I actually have your paper and have used it as my bible each time I take the carb off, etc for any reason. In preparation for the rebuild, I have actually reset to mfg spec, replaced all gaskets and reset based on your paper.
In terms of ability to tune, I definitely cut my teeth while tweaking the engine the last year and a half since I bought the BG. I am feeling much more comfortable with it and the addition of a wideband AF gauge is helping as well.
If you think the carb is workable then I feeling pretty good I could get it reasonably close.
Shane
