Motor Mounts
Old Feb 14, 2010 | 01:12 PM
todds74's Avatar
todds74
Default Motor Mounts
Hey guys im installing a 406 small block in my 74 and thinking about using solid motor mounts. They are offered in a tall and short version does anyone know which would be better in a corvette..Thanks in advance for replys....
Old Feb 14, 2010 | 06:46 PM
GUSTO14's Avatar
GUSTO14
If you're building a race car, solid mounts may make sense, but if you're building a street car it probably isn't such a good idea. Something to consider however might be polyurethane mounts.
http://www.jegs.com/i/Energy-Suspens...1114G/10002/-1
These will provide most of the stiffness of solid mounts without transmitting most of the engine vibrations to the chassis.
Anything taller than a stock mount is going to add to the problem these cars already have with hood clearance. It may limit limit your intake options.
Good luck... GUSTO
Old Feb 14, 2010 | 08:23 PM
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
All '63-'82 Corvettes use the same Moroso #62530 solid mounts. You only have to have one engine attempt to escape thru the hood (BTDT) to figure out that they are a good idea on true high-perf applications. Helps stiffen the chassis a mite and maintain driveline alignment too, but do NOT install a solid transmission mount. If you opt against solids, I'd suggest at least using an interlocking type.
Old Feb 15, 2010 | 12:18 AM
todds74's Avatar
todds74
hey skunkworks that part number you gave for the moroso motor mounts show to be for a big block in the jegs mag. are they the same for small blocks too for the corvette...Thanks
Old Feb 15, 2010 | 04:12 PM
TheSkunkWorks
Moroso shows them the same # for all C2 & C3 Corvettes, big and small. See the appropriate listings near the bottom of Moroso's application chart.
Old Feb 15, 2010 | 05:39 PM
todds74's Avatar
todds74
Thanks for the link skunkworks that helps alot....
Old Feb 15, 2010 | 07:08 PM
enkeivette's Avatar
enkeivette
I use a solid one on the drivers side because the motor torques up on that side, and a rubber one on the passenger side to take some of the vibration. I honestly didn't notice a difference after I installed the solid one. People cry about it, but that's prob because they're relying on hear-say. Like 90% of the info you get on this forum.
Old Feb 15, 2010 | 11:00 PM
cardo0's Avatar
cardo0
From: Las Vegas - Just stop perpetuating myths please.
Default Try a short 1/4"x20 bolt - best deal in town.
Yep, if u look your mounts over u can figure where to drill and install a 1/4"x20 bolt (or 2) with a thin locking nut - no torque on bolt. This still gives some squish but won't come apart.
cardo0
To Motor Mounts
