Herkey Jerkey Wiper Action
Old Feb 15, 2010 | 03:54 PM
jimvette999's Avatar
jimvette999
Default Herkey Jerkey Wiper Action
Unless the windshield is really wet, I get a herkey jerkey sweep action both ways. Tried new blades, blade angle, blade pressure ect., but no luck. Has anyone had this and cured it? If so, how?
Thanks,
Jim
Old Feb 15, 2010 | 05:08 PM
Attfay Elleybay's Avatar
Attfay Elleybay
Could be a ground problem.
Old Feb 15, 2010 | 08:23 PM
oldboat's Avatar
oldboat
is rough in both directions?
if it is only in one direction then it should be the blade angle.
if jerky in both directions then it should be the tension spring is too tight.
Old Feb 16, 2010 | 09:08 AM
jimvette999
The motor action is continuous... it's the blades that grip-slip-grip-slip
It's actually the closing action that's worse but even the opening does it to some extent when the windshild is drier. I've messed with the blade angles and the arm tension. Maybe I need to mess with it some more.
Thanks to you both for your response.
To Herkey Jerkey Wiper Action
