Hi C,
I used tape to hold the strip in place first to see how it would fit. I ran some tape to see were the adhesive that sarge suggested would go. I then put the adhesive on the strip and door and used tape to hold the strip in place as I proceeded. Follow the adhesive instructions on the tube... 2 coats.
Not too tough a job if you proceed with a bit of caution.
Regards,
Alan
You can see the tape marking the place for the adhesive and the blue tape hold the strip in place after gluing.
