1973 replacing front bumper
Old Feb 16, 2010 | 10:20 PM
Mr. Hayes's Avatar
Mr. Hayes
6th Gear
Default 1973 replacing front bumper
I am replacing the front bumper of my '73. What are your recommendations for suppliers and for retainer kits? T-kits are going for about $29 while the stock kits are $79. Any suggestions or advice is greatly appreciated.
Old Feb 16, 2010 | 11:10 PM
jordan89's Avatar
jordan89
Willcox has the front flexiglass bumper:
http://willcoxcorvette.com/product_i...ducts_id=24296
Retainers:
http://willcoxcorvette.com/product_i...ducts_id=24023
I ordered my rear bumper from Willcox along with both front and rear retainers. Willcox is the way to go.
Old Feb 17, 2010 | 01:52 PM
oldsarge's Avatar
oldsarge
I guess that depends if you are looking at being correct or judged. I prefer the original urethane, for original look. Others will say otherwise, All three types of front bumpers have their each, pros and cons. That is something you are going to have to decide. Good luck.
Old Feb 17, 2010 | 05:44 PM
manofsteel1's Avatar
manofsteel1
Default Front Bumper
From looking at the picture from Wilcox, I see that there is a molded in piece in the center. Is that for real. I have the center grill that goes there and do not want to buy it if I can not put the "rare" center grill back in. Does any one have 1st hand experience? Thanks
Old Feb 17, 2010 | 06:15 PM
vettehardt's Avatar
vettehardt
I think that is a picture of the 75-79 bumper. If you look at it it has the bumperettes. Also look at their 75-79 bumper and it is the same picture.
I went with a trueflex bumper from bairs. I have had it for 3 years now, but still haven't put it on. I have alot of other fiberglass work to do before I do. I bought the individual retainers from mid america.
Old Feb 17, 2010 | 06:35 PM
blckslvr79's Avatar
blckslvr79
I agree that is a picture of the 75-79 bumper. The 73-74 is different.
The T bolt brackets are for fiberglass bumpers, not rubber. If you choose the glass bumper you don't need the continuous support of the factory style mounts. On the other hand, with a rubber bumper, you'll probably need the larger, continuous mounts to suck it up tight to the body.
Rubber bumper will be easier to install and align. Fiberglass and Flex-fit will need glass work to fit properly. All our cars are different.
Old Feb 17, 2010 | 07:02 PM
Jeffery73's Avatar
Jeffery73
St. Jude Donor '08-'09-'10-'11-'12-'13
I used a fiberglass replacement from ACI. I had to spend 10-15 hours working on it to get it to fit properly. It was worth it though. It turned out great.
Old Feb 17, 2010 | 08:30 PM
blckslvr79's Avatar
blckslvr79
Installing a new Flex Fit on my '79 now. Fitment is terrible. Seam is tight in some places and 1/4 gap in others. One end fits the car well and the other is 1/4 long!
Bought it from Ecklers and they said too bad.
It'll take some fixing.
The rear bumper though.... fit very nicely.
Old Feb 17, 2010 | 08:37 PM
redwingvette's Avatar
redwingvette
I bought my True-flex bumper from Willcox.
It took a little extra time to get it to fit but not a lot of work. All cars are different so the time it takes verys.
Old Feb 17, 2010 | 08:45 PM
Mr. Hayes's Avatar
Mr. Hayes
6th Gear
Thanks for all the replies. I am thinking of the flexfit now. Still not sure about which brackets are best.
Old Feb 17, 2010 | 08:56 PM
blckslvr79's Avatar
blckslvr79
With Flex fit, the T bolts work just fine.
You can also go down to your local hardware store and buy 1/4 inch bolts, lock washers, and large flat washers. Same thing.
I wouldn't buy the expensive stock hardware unless you go rubber.
Once you get to fitting the flex fit, you'll see what I'm saying.
Old Feb 17, 2010 | 11:22 PM
chvet73's Avatar
chvet73
I like my fiberglass one from J&D
Old Feb 18, 2010 | 12:22 AM
wrw2497's Avatar
wrw2497
Default 73 front bumper
DO NOT buy from ecklers....fiberglass P O S and the chinese T bolts all came apart....at the worst time....I have had it with ecklers chinese ****...
To 1973 replacing front bumper
