While hanging my new exhaust I found two bolts on the front of the frame crossmember that the exhaust passes through. Each bolt is to the outside of the exhaust, one on the passenger side and one on the driver side. Kind of looks to me like an electrical connection, or some type of safety wire like is used on the seatbelts. I looked in the AIM but couldn't find anything. Any ideas?
Hi OS,
I believe that 68-70 cars with a factory option radio had the 2 ground straps at the tailpipe clamps. They also had a single strap from the underbody re-inforcement to the frame located at about the position of the driver's left foot. 70-72 cars didn't use them.
Regards,
Alan
Hi OS,
Regards,
Alan
Thanks Al, again you have come to the resue, you are a plethera of info. I did not remember doing that and was just wondering, if I had missed something.
