no start
Old Feb 18, 2010 | 01:11 PM
BigJim13 JR.'s Avatar
BigJim13 JR.
Default no start
HI,
74 corvette been running great for a year, drove it day before yesterday started is running strong starts better than most newer cars ive seen. went out today, starter doesn't even turn over... got nothing when i turn the key.
all fuses check out
car in park: doesnt turn over
car in neutral: still doesnt turn over
can it still be the neutral saftey switch??
thanks!
Old Feb 18, 2010 | 01:39 PM
78pace's Avatar
78pace
If you turn key no click out of starter, problem could be starter
Old Feb 18, 2010 | 02:42 PM
SanDiegoPaul's Avatar
SanDiegoPaul
From: San Diego - Deep Within The State of CONFUSION!
Originally Posted by BigJim13 JR.
HI,
all fuses check out
thanks!
Check battery connections for corrosion and verify power at the starter. If you have power at the starter, then make sure the exciter wire has power to the solenoid when the key is in the crank position. Let us know what you find.
RE: the neutral safety - if it won't crank in either park or neutral, I doubt that's the problem. But you could hold the ign key in the crank position with left hand while moving the shifter up and down ... I guess it's possible that it could not be positioned right, to find either P or N. But that's a long shot.
Old Feb 18, 2010 | 02:55 PM
bluthundr's Avatar
bluthundr
Make sure the car is in neutral or park, double check that the car is in neutral or park, pull the parking brake, chock the wheels, then jump the big terminal to the solenoid with a screwdriver and see what happens. If it tries to start, it's a wiring issue. If it does nothing, it's a starter issue.
Old Feb 18, 2010 | 09:56 PM
my 76 ray's Avatar
my 76 ray
Turn on the headlights and watch them while someone tries to start it. If the lights dim then it's probably the starter sucking the juice but not turning. If the lights do not dim then usually the solenoid is not making contact to get the juice to the starter. In that case, it could be the solenoid, neutral safety switch, ignition switch, battery or wiring (which would include the battery cables).
Old Feb 18, 2010 | 10:50 PM
mydejavooo's Avatar
mydejavooo
Check fuses, and check fusible links. Those can go bad, and they are hard to spot right away. A voltage meter will tell you if you have power there or not. Then check the n/s switch with a test light. It should have the light on when in park and neutral, and go off when you go through the gears. If no power there, then that switch is bad. If you have power there, then most likely your starter or solenoid took a dumpsky on you. The solenoid may have shorted out, but it's just easier to change the whole she-bang, rather than just replacing the solenoid. Hope that helps!
Deja
Old Feb 19, 2010 | 04:23 PM
BigJim13 JR.
HI,
thanks for the replys!
i hate corrosion.... had an issue with the neutral switch not too long ago so that was my first thought. little bit of water got in the car last time it rained...oops
thanks guys! appreciate it
To no start
