Need advice on FFFF! Clip Torque procedure
Old Feb 18, 2010 | 09:17 PM
2K-C5's Avatar
2K-C5
Default Need advice on FFFF! Clip Torque procedure
My 69 AIM says to Torque the Axle bolts to 60-90 lbs. But my French Clip got bent up well before I was at 70 lbs.
Any tips on preventing the F clip from turning while I torque the bolts?
TIA
Old Feb 18, 2010 | 09:25 PM
SteveG75's Avatar
SteveG75
You need better French Clips. PM sent.
Old Feb 18, 2010 | 10:02 PM
7T1vette's Avatar
7T1vette
Exactly. The originals were heat treated so they wouldn't get gouged by the hex head nor bend under torque load. The present aftermarket "gypos" are just mild steel. The tang on a mild steel part might not even retain the bolt if it started to work loose. Either find the correct parts or use lock washers.
Old Feb 18, 2010 | 11:10 PM
2K-C5's Avatar
2K-C5
Thanks guys.
I will try to get the Good ones.
If not, I know that Lock Washers work, although I will need to see if I need longer bolts. I need to make sure I have plenty of thread depth before I torqued the bolts with a Lock washer decreasing the depth.
Old Feb 19, 2010 | 08:05 AM
mysixtynine's Avatar
mysixtynine
Hey could you guys send me the place you got your french clips from too?
My body is still off and I noticed the same thing. Was kinda bugging me.
Old Feb 19, 2010 | 08:23 AM
Golden's Avatar
Golden
What's a french clip guys, I assume we have an equivalent and we use a different name?
Old Feb 19, 2010 | 08:48 AM
7T1vette's Avatar
7T1vette
A French "lock" is a strip of metal that mounts under two [usually] bolts which has little tangs that are bent up next to those bolt heads (after torquing it) so that the bolts cannot work loose. These are used with the rear axle U-joint flanges and under the mounting bolts for the exhaust manifolds on C3 Corvettes.
Old Feb 19, 2010 | 02:09 PM
Golden's Avatar
Golden
Ahh cool, so something like these.
We call them lock tabs or lock plates.
Old Feb 19, 2010 | 02:24 PM
Gordonm's Avatar
Gordonm
Lock washers work just fine. Those french clips are for the birds. A little loctitie with a lock washer and they are not going to move. If it is NCRS use the French ones if not use lock washers.
Old Feb 19, 2010 | 05:41 PM
Dustup7T2's Avatar
Dustup7T2
Terrorizing Orange Cones
Well... that comment really bolstered my confidence from the Bubba to the acceptable. That's the solution I used after having the same result with the French locks supplied in a kit.
Nothing against the NCRS crowd and just wanted to feel I'm not chasing half-shafts falling out from under the car. LOL.
Thanks Gordonm!
To Need advice on FFFF! Clip Torque procedure
