I'm re-doing the rear suspension in my 69 small block. I have a 400HP 383, 700r4, and 3.08 gears. How strong are the u-bolts on the half shaft at the differential yokes? Is there an advantage to upgrading to big block yokes, or the Drag Vette billet caps? Or do I not need to be concerned at this power level? Has anyone purchased these caps?
They are plenty strong enough...as long as you are using the correct Grade of bolt. I believe the U-joint bolts are Grade 5, so you could use either Grade 5 or Grade 8 bolts. Grade 3 bolts are fairly soft and could snap [or stretch] under load. Standard hardware store stuff is Grade 3.
Some people here are confusing U bolts with U joints. The OP asked about the factory U bolts and nuts that hold the inner U joints.
For what it's worth, I replaced the U bolts with the Drag Vette billet caps on mine. They fit nicely and they are holding up OK but I never had a problem with the stock U bolts either.
