Thrust Clearance.. Confused!
Old Feb 21, 2010 | 02:47 PM
FRSTR90's Avatar
FRSTR90
Default Thrust Clearance.. Confused!
So, some of you know I'm building a 454.. I am just now putting it back together with a different block. This block was casted around '90-'91. What I noticed different about this block and my '66 block is that this has a dowel pin to locate the #5 cap. When the cap is in place not torqued down at all the #5 cap cannot move forward nor backward. How do I go about setting the thrust clearance?
Old Feb 21, 2010 | 03:16 PM
billla's Avatar
billla
St. Jude Donor '14
Ummm...thust clearance isn't ever set by moving the bearing cap. If it's too tight, the thrust bearing surface is sanded on a surface plate.
Perhaps I misunderstood what you were asking...
Old Feb 21, 2010 | 03:33 PM
FRSTR90's Avatar
FRSTR90
I'll just wait until my dad takes a look at it.. He knows what the hell he's doing. I was just wondering if they didn't have to be set on the newer blocks.. This is my first engine build and he basically did all the precision work the first time around.. I was just curious so I asked..
Here is another question tho.. What if the thrust clearance is too much? Say .008+
Old Feb 21, 2010 | 03:49 PM
billla's Avatar
billla
St. Jude Donor '14
.007 is the spec; if there's more than that it's time for a new crank. There are no oversize bearings to my knowledge.
Old Feb 21, 2010 | 04:16 PM
FRSTR90's Avatar
FRSTR90
My clearance right now is less than .004.. Thanks for the info tho!
Old Feb 21, 2010 | 07:00 PM
forvicjr's Avatar
forvicjr
Think he was refering to seating the rear main. I give the crank a good wack back and forth with a dead blow to align the thrust surface of the rear main bearing. I do this to get an accurate thrust measurement.
Also the clearance of 4 thousanths will run, If your perticular you can pull the bearing and hold the halfs together and find a flat surface lay down some red scotch bright and evenly rub your clearance in. Claen the bearing really good before you reinstall it!!
Old Feb 21, 2010 | 07:48 PM
billla's Avatar
billla
St. Jude Donor '14
< .004 is out of spec; .005 is the minimum.
If you're referring to seating the rear main bearing, this still doesn't move the cap.
Old Feb 21, 2010 | 08:32 PM
forvicjr's Avatar
forvicjr
Yes .004 is out of spec,but by the time its started and broken in, IMO the spec would be met. As for as the cap movement, no arguement there. Locating pins wouldnt allow it. Movement would accur on engine without dowells. When seating thrust bearing rear main isnt up to torque, therefore it would move as much as the main bolts/studs would allow.
Old Feb 21, 2010 | 08:39 PM
billla's Avatar
billla
St. Jude Donor '14
It doesn't work that way - if a spec like this is too tight, the bearing can gall at initial start up.
There's a difference between aligning the bearing and "moving" the cap - but I guess it's splitting hairs.
'nuff said from me
Old Feb 21, 2010 | 08:43 PM
forvicjr's Avatar
forvicjr
'nuff said - scary stuff on this thread
I agree..................................T oo disagree.........
Old Feb 22, 2010 | 12:02 AM
jordan89's Avatar
jordan89
'nuff said from me
Old Feb 22, 2010 | 09:24 AM
jackson's Avatar
jackson
BBC or sbc ... no matter ... primarily via choice of rear main bearing ... they're commonly available with oversize flange lengths to accommodate worn undersize thrust surface on crank. A bearing w/longer flange moves flange aft & closer to thrust surface. Suggest visit your local machine shop.
*everything on internet's suspect; including the very words I just wrote.
Old Feb 22, 2010 | 12:51 PM
billla's Avatar
billla
St. Jude Donor '14
A pointer to these "thicker" rear main thrust surface bearings would be appeciated - I have never seen them.
Old Feb 22, 2010 | 01:31 PM
Manuel Azevedo's Avatar
Manuel Azevedo
Greetings!!
I have never seen or heard of any under size bearing to take up wear. There are over sizes such as .001, .002 and .010 for the thrust but that is for gringing a crank that will make that size without welding not for wear.
Yes you do set the rear cap when there is no dowel pins but not with them. Also what one wants to call a spec makes a difference if you have a clutch or torque converter with a clutch needing more min clearance, .006 to .012 would not be out of line on a clutch car.
Old Feb 22, 2010 | 02:39 PM
gerry72's Avatar
gerry72
You have to look at the bearing catalogs. They really are very common and used frequently when the thrust surface has to be machined.
As to setting the bearing, torque all the caps but leave the thrust cap loose. Get a large deadblow hammer or a 5lb sledge with a block of wood so you don't mess up the machined surfaces. Smack the front of the crank with a good blow, then do the same to the rear. Now torque the cap. Set up your dial indicator and measure the thrust clearance by first prying the crank backward with a screwdriver wedged between a cap and the crank, zero the indicator, then pry the crank forward and read the indicator. You can also measure with just a feeler gauge on the rear surface between the bearing and the crank, but the dial indicator is more accurate since there is no "feel" to it.
To Thrust Clearance.. Confused!
