Good cam needed, please help.....
Old Feb 23, 2010 | 11:35 AM
c3_dk's Avatar
c3_dk
Default Good cam needed, please help.....
I am looking for a good street cam with a lot of power, but also good for cruising. My car is a 1969 Corvette with a 1969 SB 11:1 engine, with 4 speed transmission. I do have Brodix IK180 heads, Rocker arms 1,6, Comp Cams lifters (853-16), headers + 2½" exhaust.
Please help me with a good Comp Cam.
Old Feb 23, 2010 | 11:59 AM
10caipirinhas's Avatar
10caipirinhas
If you haven't already done so, why not download the cam selection software from their website, and go from there. It's kinda interesting........
http://compcams.com/camquest/default.asp
Old Feb 23, 2010 | 12:49 PM
Gordonm's Avatar
Gordonm
What rear gears do you have. Are you looking to go to a roller cam, solid or hyd. cam?
Old Feb 23, 2010 | 12:59 PM
captl27's Avatar
captl27
I have had good luck with Crower cams (roller hydrolic) they have a spec sheet on line that you can fill out with all your specs and they will calculate the cam you need. A lot of guys along with my son in law on the camaro forum swear by them. I have a 10 to1 406 with AFR 195s and duel 4 600s with a 6 speed behind it and 373s in the rear this is the cam i picked. only got about 2000 miles on it but is runs great with more power then I will ever need.
#00470S 2400-5800 rpm 462hp @ 5800 rpm
110 - 232/240 .549"/.559" (the one I picked)
Old Feb 23, 2010 | 01:01 PM
c3_dk's Avatar
c3_dk
Thanks....
Old Feb 23, 2010 | 01:04 PM
c3_dk's Avatar
c3_dk
Hi,
I have 3,70 rear.
I will go for hyd. roller cam (I have roller lifters Comp Cams 853-16)
and 1,6 Rocker arms.
c3_dk's Avatar
c3_dk
Thanks captl27
Old Feb 23, 2010 | 02:15 PM
pauldana's Avatar
pauldana
I am running the Edelbrock Performer RPM signature cam, on a rear wheel dyno, I am at ~436tq and ~450hp.... my build otherwise is similar to yours. its a 383 stroker, and the cam runs VERY strong all the way up and through 6500 rpm.... after the new beehive springs!!.... Vacuum though is about 11" and may give you brake problems???/
Old Feb 23, 2010 | 02:20 PM
The Spark's Avatar
The Spark
I would contact the cam manufacturer and tell them what you have and what you want to do with the car. They know their product better than most. IMHO
Old Feb 23, 2010 | 02:29 PM
pauldana's Avatar
pauldana
yea, they know there product, but it is there job to sale cams... so you will never hear Edelbrock telling you to use say... a Comp cam..
You have to do your own leg work and research... ask questions, and listen... and then make an educated... decision
Old Feb 23, 2010 | 10:05 PM
brando1118's Avatar
brando1118
C3_dk,
I'm running a Comp Cams 280XFI in my QuickFuel Carburated 383. 1.6 on the exhaust and 1.5 on the intake, Dart Pro1 heads. I still need to work some things out on the QF Carb, but the car runs strong and I'm pulling 15 hg's of vacuum at idle.
Old Feb 25, 2010 | 12:07 PM
c3_dk's Avatar
c3_dk
Thanks all........
I do have a brand new Comp Cams 12-466-8, will that work?
http://www.compcams.com/Cam_Specs/Ca...?csid=175&sb=2
Old Feb 25, 2010 | 01:29 PM
brando1118's Avatar
brando1118
Hi,
I don't know how streetable 11:1 compression will be, but I don't think you would be taking full advantage of your current platform if you use this cam. If you lowered the compression ratio a little with some dish pistons or larger cc head, then that cam would be a good one for the street and would mimic your original request of being streetable and a decent performer. The cool thing about Comp Cams Fuel Injection line is they produce more vacuum in addition to good power even on carburated motors.
Old Feb 25, 2010 | 07:42 PM
pauldana's Avatar
pauldana
its got a good lift but the duration is short.... 11:1 is ok with aluminum heads, but 10.5:1 max on iron,,, still think you should take a look at the Edelbrock roller RPM cam, it has a lot more duration which will give you more HP.... Also the RPM cam runs 1500-6500, and the comp runs 1800-5800..... Also increasing rocker geometry, such as going from 1.5 to 1.6 can ware valve guides much more rapidly, the edelbrock signatures has more lift then the RPM and you can stay with 1.5.... just mho...
Old Feb 25, 2010 | 10:45 PM
63mako's Avatar
63mako
St. Jude Donor '08-'09
Originally Posted by c3_dk
Thanks all........
That won't work. You will detonate the pistons right out of the cylinders on pump gas. If you have a true 11 to 1 you need 240 duration @ .050 on the intake to run pump gas period. This cam will work. http://www.compcams.com/Cam_Specs/Ca...?csid=162&sb=2
It is a lot of lift with 1.6 rockers. The XE288 HR might work. It is the next size smaller but your 1.6 rockers would bump the duration up about 3 degrees. If you go with it you need to order it with a wider LSA 112 or 114 to help idle, widen the powerband and keep you out of detonation trouble. Hard to get an off the shelf hydraulic roller for that much compression. Cams for that much compression are higher rpm cams and the Hydraulic rollers with their heavier lifters run into valve float issues @ 6000 to 6500 RPM unless you have a rev kit. lightweight valvetrain components, beehive springs or a combination of the above.
Old Feb 25, 2010 | 10:58 PM
pauldana's Avatar
pauldana
hey... this is the guy to listen to... I went throught a spring issue, and he is like... on top of it thx again 63mako!! those beehives are the fraken bomb!!!! still need to look at the RPM.. duration 234 238
Old Feb 25, 2010 | 11:23 PM
63mako's Avatar
63mako
I have been wondering how the beehives worked out for you. Does it pull hard all the way up now?
The RPM would work but you need to close the intake valve sooner to reduce cylinder pressure, Install advanced 4 degrees would do it and lower peak torque RPM. The 112 duration will help too. Might be a good option. Interesting reading here.[url]http://compcams.com/technical/FAQ/LSAproperties.asp[/url
With the lift numbers you are going to be at and installing advanced you really have to be careful on piston to valve clearance.
To Good cam needed, please help.....
Old Feb 25, 2010 | 11:39 PM
eagle275's Avatar
eagle275
Default ...
Old Feb 26, 2010 | 12:56 AM
pauldana's Avatar
pauldana
Haven't gone back to Cms for there dyno run but did run it at R&E and yea... ran all the way up.. there dyno is an inertia dyno and gives lower readings then CMS's braking dyno numbers I posted, but I will be revisiting CMS in the next 6-8 weeks for another dyno and will post the numbers on the old thread, but if I go by the inertia dyno, I should be about 440tq and 460hp at he rear wheels, up over 50hp.... it is amazing, it pulls all the way through 6500RPM....buddy has a pretty modded 3rd gen rx7 twin turbo... took a ride with me and he said he could not believe how hard it pulls and just keeps pulling.... burn rubber all the way through 1st, and hard to hold down through 2nd... thx again!!!! beehives rule!
Old Feb 26, 2010 | 12:48 PM
c3_dk's Avatar
c3_dk
Thanks 63mako,
It is the factory 1969 L46 engine I have in my car. But to be honest I dont know what compression will be with my Brodix IK180 heads, can anyone help here?
But what I would like to have, is a fast street car, but also for crusing with the kids.
BR,
John
