Gas Gauge
Old Feb 25, 2010 | 07:54 PM
oleyellar72's Avatar
oleyellar72
Default Gas Gauge
where can you get the resistor strip on the back of a 72 gas gauge, or how can you work around it ?????
Old Feb 26, 2010 | 11:14 PM
Letournour 1850's Avatar
Letournour 1850
Try Napa Part # BK 7011498 it not a stripe resistor but will work $9.99 has 2 resistors
Old Feb 27, 2010 | 11:47 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Oleyeller-
The resistor on the back of the gauge is a 90 ohm resistor.
I'm not sure what the value of the napa kit is, but what I am sure of is 90 ohms resistance is what you need.
You can buy this at radio shack solder two ends on it for about 1.00.
Willcox
Old Feb 28, 2010 | 05:30 AM
7T1vette's Avatar
7T1vette
Needs to be a 5 watt resistor...
Old Feb 28, 2010 | 11:07 AM
0Willcox Corvette
Former Vendor
Yep... forgot that!
This can be made so quick and easy at such a cheap price!
Willcox
Old Feb 28, 2010 | 11:11 AM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
I agree with the Radio Shack idea. You may have to pick up a few of different values so you can get as close as you can if they do not have a 90 ohm resistor.
To Gas Gauge
