81 AC/Heat Vent question
Old Feb 25, 2010 | 11:05 PM
us marine's Avatar
us marine
Default 81 AC/Heat Vent question
ac and heat was blowing fine yesterday now nothing seems to blow from the front vents. Seems like there are stuck blowing to the bottom. Is there a vacuum or actuator that causes them to change?
What could be causing them to be stuck?
Old Feb 26, 2010 | 06:55 AM
Ganey's Avatar
Ganey
The switch is in the console attached directly to the selector for Vent/(A/C)/Heat/Defog.
Try pressing the 2 halves of the switch together.
I wrote this up awhile back for this problem.
The problem is that heater is the default position (no vac. or vac. leak) due to being designed in the north. Vent should be default. Very safe bet the problem is 1 OR 2:
1) The vac. line from engine may be damaged from heat - a small plastic tube that goes in below the hood alarm switch into wiper valley. Replacing most of engine side w/ hose will fix. OR
2) The vac. switch itself is not switching due to vac. leak as the usually plastic rivet is not holding the 2 main switch parts together well. Besides replacing, it is also possible to tighten this &/or lube w/ a thin layer of white lithium grease to fix.
3) If you have a heater, the small vac. tube to heater hose valve underhood may be damaged from heat & need replacing. Block w/o heater.
PS The design problem comment is not intended to be offensive to any of our northern friends.
Old Feb 26, 2010 | 12:37 PM
us marine's Avatar
us marine
Ha Ill give it a shot. Thanks a bunch!
Old Sep 5, 2010 | 06:50 PM
MrMootsie's Avatar
MrMootsie
Could you please amplify this at all? New owner. AC works like a champ, but only blows in lower right vent. The slide switches only seem to turn AC on, not control where the air is going.
TVM, and I'm using the search function.
To 81 AC/Heat Vent question
