Rear end removal
Old Feb 26, 2010 | 07:54 PM
psycho dad's Avatar
psycho dad
Default Rear end removal
I need to pull the rear end on my '76 to replace the clutch packs.
I have a friend who can replace the clutches for me, but I need to remove it. Anyone have or know of some good instructions? My chilton's manual is no help at all.
- Jay
Old Feb 26, 2010 | 08:07 PM
1976corvette's Avatar
1976corvette
hi if I remember correctly you have to remove the rear spring out of the car then take the drive shaft off, try to mark the shaft so you can put it back the way it came off. the next thing is to loosen the rear mounting to the front of the car and then put you r jack under the rear end so it will not fall. You may need help because you have to remove the rear crossmember and drop it as a unit. The rear end is bolted to it from the top. I may have missed a few things but this should get you preaty close.
hope this helps
viet vet with a vet
walt
Old Feb 26, 2010 | 08:13 PM
snoopykissedlucy's Avatar
snoopykissedlucy
Hot Rod/Horsepower TV did a show on this procedure about 2 years ago. I can't locate it on the net.
Does anyone have a copy of this episode?
Old Feb 26, 2010 | 08:14 PM
Paul Ruggeri's Avatar
0Paul Ruggeri
Former Vendor
Remove everything that's attached to the diff, driveshaft, halfshafts, spring, dogbones. The diff is bolted from the top to a long mount. There are 2 bolts on the ends of this mount. Remove them and usually you'll have to pry the mount down from the frame.
Old Feb 26, 2010 | 08:19 PM
jordan89's Avatar
jordan89
Shouldn't be to difficult.
Old Feb 26, 2010 | 08:22 PM
Frogday's Avatar
Frogday
hope this helps
viet vet with a vet
walt
You will also want to unbolt your half shafts, center piece the tie rods connect to, remove spare tire carrier, and remove or lower your exhaust. Don't take the crossmember bolts all the way out, leave them in place to catch the crossmember. You will likely need a pry bar or 2-jaw puller to get it to release. Once it is free the bolts will prevent it from crashing to the floor.
Old Feb 26, 2010 | 09:14 PM
Vettekid1992's Avatar
Vettekid1992
That long mount may be frozen to the chasis and u may need a crowbar to get it down. its best to let the jack sit right below the differential so that when u pry it down it drops like a half inch. if u take the tires off the car this process is much easier
Old Feb 26, 2010 | 10:56 PM
psycho dad's Avatar
psycho dad
thasks for the help... wish me luck!
To Rear end removal
