high volume oil pump?
I also have a leaking rear seal. The engine has been modified some, not sure what is in it, it has roller rockers and is supposes to make 400hp.
Would the low pressure be an indication of a need for a high volume oil pump? Or something else?
Second question the engine is running around 200deg. I figure this is fine for now but during the summer in Houston traffic it might be an issue. The radiator is old and leaks so it needs to be replaced. I know the aluminum radiators are 27% better than stock but are the heavy duty ones at an auto parts store similarly better if I don’t care about weight? My wife is on a fairly tight budget at present so cheaper is better unless I end up needing the more expensive one later.
Last question the car will not start or even turn over when hot. I have tried a heat shield and same issue. I am thinking I need a high torque starter. Assuming it is a starter what is the simplest way to determine the compression ratio? If it is too complicated I will just get a starter to cover me. A mechanic who installed the exhaust thought it sounded like 12 or 13 to 1 but that was just by sound of the engine.
Not real uncommin for an engine to run a little warm with no more miles than you have on it. Check the accuracy of your gauge too.
I'm running 12.5 compression on my BB and a stock starter with no problem- check the ground between the right motor mount stand and the block- it may be bad/disconnected/missing. And the ground from the battery to the frame. turn on the headlights and then turn the key to "start" and see what the lights do.
Maybe someone else will jump in on the compression- they only thing I can think of there is knowing what pistons are in it along with combustion chamber size, along with the usual bore and stroke.
If there's nothing mechanical wrong perhaps thicker oil would up the pressure enough - try 10W-40, 15W-50 or 20W-50 instead of the 10W-30.
The radiator in the car is shot, case leaking, core leaking, a used one the mechanic sold my wife(not at the time). I am debating between spending $250 on the heavy-duty one from the auto parts store or $500 for the Al one.
I will check the wires as that is simplest but I found a lot of posts on heat soak issues and the minni starters fixing the issue that sound a lot like my issues. When the car won’t start I open the hood wait 5 minutes and it starts just fine. I was hoping you could some how use a compression gage and calculate the compression ratio.
I know with go-karts we use to put oil in the cylinder at tdc than again at bdc and calculate the ratio but you can’t tip a car engine upside down to get the oil out.
I've never heard of being able to tell the compression ration by listening to the exhaust, that sounds like BS to me.
My stock L-48 ran at 200 till I replaced the fan clutch, it now runs at 180.
On a previous car I had the hot starting issue and it turn out to be bad wiring connection to the starter.
BTW, lots of books out there that tell you that 10 psi/1000rpm is sufficient oil pressure
Good luck.
Suggest first thing is just go buy a new op sending unit & replace it; probably $15 or less at local parts house.
Me thinks you might do same with your water temp sending unit.
If you're smart enough to wrangle a gokart motor around to figure comp ... me thinks you're probably smart enough to install a universal fit race alum rad (<$200).
*everything on the internet's suspect; including the very words I just wrote.
What is the oil presure off idle? If it is low maybe you have a problem, but if it is 40+ leave it alone. On your cooling 200 is not bad but it will probaly come down some as the engine gets a bit looser. The correct rad. in good condition and clean and all will be just fine, you would only need the other types if you had other problems or a lot of power above stock.
In most bad cases it's the pressure relief valve in the oil pump(cheap fix) or as said before excessive clearance somewhere.(expensive/this sucks fix)
TSW
TSW
Check your gauges to verify they work correctly
I agree on the 10 psi per 1000rpm
Sounds like a fresh motor and you are using a leaky radiator
Dewitts aluminum, or at least a non leaky, unblocked clean one
Did you use a new thermostat? What temp is it?
Mini starter might fix your problem on hot start, but check your timing to see what its at too it will make a diference if your dizzy is locked out on full timming
12 or 13 to 1 compression
hope you are running race gas or premium with some good octane boost!!Who built your motor or where did it come from?
There are ways to figure out your compression ratio you just need to know the numbers but to know that you need to know the exacts on your motor from your builder or where you got it from. Example bore size, piston in the hole from deck, piston profile, gasket thickness, head chamber size + or - mods and cut down on heads.
From what I've seen it's typical to have a bit more than the 10/1000 at low RPM's.
What gets me is the all to common thought process that if some is good, more is better. Guys, SBC's and BBC's just don't need huge pressures to be "safe".
I did replace the electric OP sending unit this evening to make sure it was reading correctly. However I have not cranked it to see if that made a difference yet.
20 PSI at idle warm with 10W-30 is not bad. I think 10W-40 is fine for these engines in most applications. 10W-30 is for newer engines. They are designed with tighter clearances. Synthetic will generally show lower pressure.
If the pressure goes up nicely and smoothly as you accelerate, reaching at least 30 psi during normal driving (i.e 45-55 mph), you're good to go. That said, I personally prefer a high pressure pump and have run one in both my Corvettes. Just makes me feel better knowing I have 60-70 PSI at 6500 RPM.
Water Temperature: Texas is hot. I lived in Houston when I rebuilt my current small block. After the rebuild, while I could keep it at 200 degrees on a normal day driving on a hot day it would go to 230 degrees at a stop light. Same fan, shroud, etc. I bit the bullet and installed a BeCool aluminum radiator. Same fan, same shroud. (This is a 74 so it's all mechanical.) I never go above 180 any more. Best decision I made - just expensive.
Wade
Spring pressure behind the bypass valve determines when it will open. If it is designed to open at 60 psi, it doesnt have any effect on anything below 60 psi - UNLESS IT STICKS OPEN - if it sticks open pressure will be low at idle and then build up to the 60 psi at which point the valve would normally open.
I personally wouldnt be comfortable with 10 psi at idle either and there have been good tips for you to try to determine what you need to do.
- check your pressure with a mechanical gauge - the electric senders are notorious sometimes and keep in mind its something that previous owners rarely change, yours may be original.
- look at how your pressure reacts under driving. If the engine has excessive clearances in anything but the rod bearings oil pressure will be uniformly low throughout the rpm range (compared to good clearances). If rod bearings have excessive clearance oil pressure will be low at idle and could get worse as rpm rises before going back up.
- while 200 deg wouldnt worry me much where I live, given where you live you definitly want to get that fixed. A replacement radiator from a local shop should work fine if you are on a budget. but you must make sure that you are using a fan shroud and have all the gaskets around the radiator and shroud that you are supposed to have. If you are not running the factory clutch fan then either install one or go to electric - dont use a fixed flex blade fan. You can also run a higher pressure cap.
- I doubt very much you are running even close to 11:1 CR as you pointed out judging compression by the sound of the exhaust isnt exactly the same as having measured it. In any case for a small block to make 400 hp (assuming it actually makes that - claims from builders/sellers are often inflated) you dont need anything near that kind of CR.
- Your starting issue sounds like heat soak - does the solenoid even click when you turn the key? Get your engine temps down and this likely goes away, otherwise a heavy duty solenoid, or a mini starter are all possible solutions.
- fix the rear seal, leaky vettes arent much fun
Did you purchase the motor? or did the seller claim to have replaced the motor prior to your purchase? in any case 10 psi at idle with 10 miles on the motor is reason enough for me to go back to the builder, similarly the rear main seal shouldnt be leaking with so few miles unless the seal wasnt installed properly, I know of no break-in period for the lip seals used in the small block, they either work or they dont.
I have no doubt in Smokeys reccomendation its been used for many years as a rule of thumb, but it seems to me that Ive never seen a factory car straight from the factory with 10 psi at idle, Ive never owned a GM car that had that kind of OP from the factory. I dont have an owners manual but I would be interested to know what it may say about OP. I would want at least 20 psi @ idle when hot
