Hood problem
Old Feb 27, 2010 | 04:29 PM
Sho'nuff's Avatar
Sho'nuff
Default Hood problem
How do you open a hood that will not open when you pull the handle?? Only one side is releasin, the passenger side...grrr
Old Feb 27, 2010 | 04:35 PM
veronicas dad's Avatar
veronicas dad
try pushing the hood release as far in as you can thenm have some one LIGHTLY push down on the driver side where the latch is and try pulling the release. my hood had some problems too, its quite a mission to figure out the right combination to open your hood lol. i sprayed a ton of wd40 on the linkage and it worked like a champ after that.
Old Feb 27, 2010 | 04:41 PM
Sho'nuff's Avatar
Sho'nuff
was working fine. Removed hood and it was closed misaligned. I thought i saw a pic on here that showed how to get to the release.
Old Feb 27, 2010 | 05:32 PM
garage-ghost's Avatar
garage-ghost
Have someone pull on the hood in the direction of better alignment then pull the release.
Old Feb 27, 2010 | 05:36 PM
Ganey's Avatar
Ganey
Push pass. side back to lock & pull release quickly.
There are 2 plugs (1 per side) in the wiper valley, push them out to get to hood latches.
Old Feb 28, 2010 | 08:50 AM
Sho'nuff's Avatar
Sho'nuff
thanks, i will try this today, crossed fingers.
Old Feb 28, 2010 | 09:52 AM
dannyman's Avatar
dannyman
Did you get it open yet?
If not:
http://www.mamotorworks.com/corvette-1-0-3852.html
Detail photos and description of procedure.
Old Feb 28, 2010 | 09:59 AM
Ganey's Avatar
Ganey
Sho'nuff
See your PMs.
Old Feb 28, 2010 | 09:08 PM
Sho'nuff's Avatar
Sho'nuff
Hood fixed. Removed tire and using vise grips, backed off hood hinge bolts from under fender well. Thanks for all the info!
Old Mar 1, 2010 | 02:25 PM
croaker's Avatar
croaker
Nice color
Old Mar 18, 2010 | 03:08 PM
marcusmd's Avatar
marcusmd
Does anyone have a diagram for where the hood release cable passes through the firewall? I'm still trying to get my hood open, but I was wondering if anyone had this info. Thanks.
To Hood problem
