Headlight problem
Old Feb 28, 2010 | 08:10 PM
bmack's Avatar
bmack
6th Gear
Default Headlight problem
New to the Forum and Corvettes, so please forgive my ignorance. My headlights won't flip up on my '77 when turned on. I know the system works on vacuum. Any ideas on troubleshooting would be appreciated.
Old Feb 28, 2010 | 08:13 PM
jordan89's Avatar
jordan89
Have you rebuilt the headlight actuators, checked for leaks? There are many reasons for this very common problem.
Old Feb 28, 2010 | 08:18 PM
bmack's Avatar
bmack
6th Gear
Just got started addressing the problems with this car and thought I'd use the forum for a sounding board. Thanks for the advice on the actuators.
Old Mar 1, 2010 | 10:02 AM
Alan 71's Avatar
Alan 71
Hi B,
There are several long threads about headlight and wiper trouble- shooting on this forum and also some trouble-shooting guides availible here, on the net, and from various vendors.
Can you describe what's going on...? Does anything happen? Do you hear anything, like a hiss? Did they ever work? Did you or anyone do any work on the car that might have caused this problem by accident?
Regards,
Alan
Old Mar 1, 2010 | 11:42 AM
jotto's Avatar
jotto
Also, have you tried the override switch for the lights under the dash, kinda central under the steering column....simple push pull switch. Sometimes if the main light switch goes faulty so this can be used instead.
As a side note, I know you said you are new, does anything happen when engine is running and you pull on eother the light switch or the over ride?
A few more details and you will get the answers you seek.
Get yourself a hand held vac pump and check out this for starters.
http://willcoxcorvette.com/repairand...lp.php?hID=218 Click on the supporting documents link.
Good luck!
Old Mar 1, 2010 | 01:34 PM
bmack's Avatar
bmack
6th Gear
Tried the overide switch. The lights do come on when I turn on the headlight switch, they just don't flip up. I think it's a vacuum problem. I really don't know what's been done to the car.
Old Mar 1, 2010 | 01:46 PM
Ganey's Avatar
Ganey
If you open the hood you can get to the hoses to troubleshoot. There is a vac. tank w/ 2 hoses, one to each side & another source. So check for vac. The vac. tank can be bypassed.
Each side can be checked separately.
To Headlight problem
