hooker inserts
Old Mar 9, 2002 | 04:12 PM
mncus11's Avatar
mncus11
Default hooker inserts
I have hooker sidepipes but i dont have the mufflers or baffels yet. does anyone have any suggestions? i dont want to go with the eckler inserts bec i did not hear good things about them. and i dont want glass packs because they always sound like s**t. i read on here before about a company called turbo somthing does any one know the webcite or have any suggestions on other makes for these inserts
THanks Marc
Old Mar 9, 2002 | 04:25 PM
bence13_33's Avatar
bence13_33
Default Re: hooker inserts (mncus11)
Your best bet is to get a pair of JCL Spiral Baffle Inserts. These are the least restrictive and provide a great sound. Your other two main choices are Hooker glasspack inserts or reverse flow mufflers. Both of those choices are very restrictive (especially the reverse flow mufflers). Personally I like the sound of the glasspack mufflers but these are still restrictive when compared to the JCL Spiral Baffles.
Old Mar 9, 2002 | 04:30 PM
Scott78's Avatar
Scott78
Default Re: hooker inserts (bence13_33)
For inserts for Hooker sidepipe, Spiral Turbo Specialties (JCL's) are the best choice for power and sound IMHO. Some tests have shown both HP gains and sound reduction. http://www.spiralturbobaffles.com/
Scott
Old Mar 9, 2002 | 05:30 PM
69ttop502's Avatar
69ttop502
Default Re: hooker inserts (Scott78)
Hands down slam dunk for the baffles. I have them and have dyno tested them and there is no other way to go with sidepipes and you will love the sound. Bill.
Old Mar 9, 2002 | 05:49 PM
C3 Shark Tank's Avatar
C3 Shark Tank
Default Re: hooker inserts (69ttop502)
I got my baffles a couple days ago, haven't put them in yet since Jet-Hot still has my headers. I did test fit them and drill the holes for the mounting tabs, went in and out real easy. I would strongly urge people NOT to use the mufflers or glass packs, it took a week to get those stinking things out of the sidepipes. After they are in a while they rust and you'll go mad trying to get them out. I used a couple cans of WD40, 2 quarts of used motor oil and they still wouldn't come out. I had to rig up a small piece of pipe with strong wire around it then push it through the muffler and tied it off to a bench vise, and even then it was a real PITA to get them out. I HATE THOSE STINKING MUFFLERS! :mad :jester
Old Mar 9, 2002 | 06:53 PM
Chuck Harmon's Avatar
Chuck Harmon
I am using the JCL baffles too and think they are unquestionably the best option out there for side pipes. If you open my web page by clicking the url on my sig, you can either select the Blue L88, or just click on its photo on the web page and you can hear an old recording of the car with JCL baffles. I need to make a newer recording running up to its 7000 redline with maybe a power shift or two thrown in:D The recording is only of about 5000 rpm before the engine was broken in. 1st and 2nd gear are simply burnouts, the tires couldn't hold it. I had to lift in 3rd gear due to merging with rather heavy traffic at the end of the on ramp.
For that matter, you can also click on my Z's picture and hear it too. I think I was shifting around 6000 rpm. It would have been too embarrassing to hit the rev limiter (very easy to do) at 6500 on the recording. The engine spools up faster than the tach in first and second. The electronic tach is only reading about 5800 when you hit the rev limiter in first. :(
Chuck
Old Mar 9, 2002 | 08:23 PM
JCL's Avatar
JCL
Default Re: hooker inserts (Chuck Harmon)
Thanks guys! JCL :cool: :cool: :chevy "Sidepipes are the way"
Old Mar 9, 2002 | 11:40 PM
mncus11's Avatar
mncus11
where do i get the jcl baffles is there a webcite or a mag that u suggest? i cant find anythign on the web about them htanks marc
Old Mar 10, 2002 | 12:05 AM
Steve Straus's Avatar
Steve Straus
Old Mar 10, 2002 | 05:56 PM
2nspire's Avatar
2nspire
Default Re: hooker inserts (Steve Straus)
I have two sets of the Hooker glasspacks and they are a waste. I'll be puting in the JCL's.
To hooker inserts
