Hello all,
I've got a picture of an RPM Air Gap I'm interested in purchasing. The picture is of the port where the runners meet the head. There are holes in the upper part of the runners and they looked tapped. Is this the way they come from the factory? It seems like fuel/airflow would be disturbed. Anybody ever see these when they installed their RPM Air Gap?
Thanks for the help.
Brando1118, the Air-Gap is usually not offered with those bosses tapped. Here's an image of mine:
I don't imagine airflow is disrupted much, if at all without something protruding from the hole. That is also subjective and open for discussion.
I imagine Edelbrock molds them if you choose to tap for fuel injection or NOS nozzles. If the one you are reviewing has them opened, I'd expect they're tapped for pipe threads therefore, some appropriate plugs will seal any vacuum leaks. If not pipe threaded, you may wish to continue surfing as any leaks would be troublesome, especially on a C3 with vacuum-dependent sub-systems.
Hope this helps.
BTW: the ports in your image look pretty rough and not from a manufacturing viewpoint. I wonder if Bubba was attempting to recreate a magazine article he read?
Thanks Dustup7T2,
Yeah, the port clean up job does have a *bubba* like touch to it doesn't it? I don't think the holes go all the way through. It would be impossible to tap those holes without having access from the top, so that is why I wonder if it came from the factory like this.Here is the top of the intake:
The ports have been drilled and tapped for Nitrous injectors and then welded closed from the outside - notice how your nitrous bosses have a "rounded" appearance. After welding, the manifold was bead blasted to give it a uniform appearance. If too much heat was put into it during welding, the manifold flange can be twisted.
