502 Torque converter
Old Mar 3, 2010 | 08:43 AM
rbat's Avatar
rbat
Default 502 Torque converter
Do I need to replace my stock converter in a th400 (both were rebuilt) for a stock zz502. I am looking for drivability (street) not strip performance. If not, what is recommended. With normal tires I will have more power than I will be able to apply to the ground.
Old Mar 3, 2010 | 09:24 AM
7T1vette's Avatar
7T1vette
In a word...."Yes". You need to buy a good brand name torque converter (B&M, etc.) and give them the specs for your engine (HP and torque curves...or best estimate of that info). The torque converter needs to be selected via engine torque, max. rpm expected and the kind of driving that you will be doing. A 'performance' converter is much different from a 'street use' converter. Call their techs first, and have them help you choose the right converter.
Old Mar 3, 2010 | 09:37 AM
Mastr Fab's Avatar
Mastr Fab
I don't agree. Since stall speed is based on torque output, the same converter will have a higher stall speed with a bigger engine. While it's true that the combination might not be optimal from an all out performance aspect I don't think you would notice the difference while street driving. IMO.
Old Mar 3, 2010 | 04:15 PM
7T1vette's Avatar
7T1vette
Good luck using the stock converter.
Old Mar 3, 2010 | 08:06 PM
l88rocket's Avatar
l88rocket
a guideline suggestion I would go with a 12 or 11 inch converter with a 2500 stall, and you will also need a good tranny cooler when you upgrade the converter it will build a lot more heat now
To 502 Torque converter
