Lars recurve kit?
Old Mar 9, 2002 | 09:43 PM
C3Vettesrock's Avatar
C3Vettesrock
Default Lars recurve kit?
What is this and how will it affect my car, i just had a zz4 installed around thanksgiving...any hp gains or anything?
Old Mar 9, 2002 | 09:55 PM
lars's Avatar
lars
Default Re: Lars recurve kit? (C3Vettesrock)
C3V -
The gains you get from the kit are really dependent on how far off your current ignition curve is. If you're running a bone stock GM/Delco HEI, the advance curve is slow and short. This severely hampers performance, and you can get a noticable improvement in throttle response and off-idle torque by running the kit.
Some of the aftermarket distributors have very good curves in them, and are set up correctly. If you already have a distributor with an aggressive advance curve that will bring in the 36-degree total timing at the right rpm, you have little if anything to gain from the kit.
If I were you, I'd take an adjustable timing light to the current setup and see how much total timing (with vac advance disconnected) you're getting, and at what rpm it comes in. If you're getting less than 32 degrees total timing, and the total is coming in above 3500 rpm, you will get improvements with the kit. If your current setup is giving you 36 total advance at or about 2500-3000 rpm, the kit won't gain you much.
Drop me a note if you need any clarification on any of this or if you have any questions. Also, I think there is a product review on the kit in one of the product review sections. I just e-mailed you 3 MS Word documents with info about the kit and about its development.
[Modified by lars, 7:58 PM 3/9/2002]
Old Mar 9, 2002 | 09:58 PM
C3Vettesrock
Ok i hope to get my car back monday, i totally messed up my transmission last friday night, its getting rebuilt at the moment and when i get it back ill let you know how its looking...thx for the info
Old Mar 10, 2002 | 05:08 AM
VETDRMS's Avatar
VETDRMS
Default Re: Lars recurve kit? (lars)
C3V -
The gains you get from the kit are really dependent on how far off your current ignition curve is. If you're running a bone stock GM/Delco HEI, the advance curve is slow and short. This severely hampers performance, and you can get a noticable improvement in throttle response and off-idle torque by running the kit....
Ok, this may be a bit out there, but where could i get this? I do have the stock GM HEI, just installed my headers, using some Accell U-groove plugs with some moroso 8mm wires...would this help me?
Old Mar 10, 2002 | 11:44 AM
CORKYVET's Avatar
CORKYVET
Lars,
You state " some of the aftermarket distributors have very good curves". Can you be specific? I'm thinking of replacing mine after I finish this cam and heads installation. Thanks in advance.
To Lars recurve kit?
