U-joint ?
Old Mar 3, 2010 | 07:05 PM
Attfay Elleybay's Avatar
Attfay Elleybay
Default U-joint ?
On an '80 vette, are all 6 u-joints the same size? I need to replace one on the driver's half shaft. I'm going to replace both since I'll have the shaft out anyway. If you have an autozone part #, I'd be grateful.
Old Mar 3, 2010 | 08:13 PM
1980 blue L48's Avatar
1980 blue L48
Automatic trans 80s uses all half shafts the same. Your driveshaft are 2 different sizes, none of which are like the halfshafts. Sorry no numbers.
Old Mar 3, 2010 | 08:21 PM
Tim81's Avatar
Tim81
I just went through this with my 81. The drive shaft were different size from the half-shaft. The best thing to do is take the old joint with you to compare the size to the new joint. Tim
Old Mar 3, 2010 | 08:55 PM
Grumpy 427's Avatar
Grumpy 427
I just did mine, and all 6 were the same size on my car. All 6 were the bigger 1330 HD ujoint. They were a Precision brand ujoint, part number 254. Here is the summit add for them. I know the drive shaft were supposed to be different, but i learned otherwise.
http://www.summitracing.com/parts/PCN-254/
Old Mar 3, 2010 | 08:57 PM
Grumpy 427's Avatar
Grumpy 427
application guide as well.
http://www.summitracing.com/parts/PC...TE&prefilter=1
Old Mar 4, 2010 | 12:37 AM
Goody's Avatar
Goody
I have an '81 4spd and they are different joints for the driveshaft and halfshafts. I ordered genuine solid dana/spicer units.
I want to say they are 1310 for the driveshaft and 1350 for the halfshafts.
Old Mar 4, 2010 | 12:55 AM
Bud2's Avatar
Bud2
Bud2
Default I agee with Goody above....
I'll be replacing all my u-joints this winter. My understanding is Spicer 1310 for the drive shaft and 1350 for the half shafts. But I'd also take the old one in just to be sure.
Bud.
Old Mar 4, 2010 | 07:35 PM
68/70Vette's Avatar
68/70Vette
The original AC Delco U joints are still available. I think the part number is 89029305. The rear half shafts use the same U joint. Don't know about the driveshaft except on an auto tranny the ujoint to the tranny is often different.
Make sure you buy good quality U joints. Non greasible are stronger. Spicer seems to have a good reputation, but sometimes they sell the same part in two or more quality ratings so be careful.
Old Mar 5, 2010 | 11:13 AM
rj8806's Avatar
rj8806
The u-joints came in 3 sizes(most popular). You can measure the old one's and compare to this information....:
1310 series 3 -1/4" across the caps and a 1 -1/16" cup diameter. rated at 400ft/lbs continuous
1330 series... 3 -5/8" across the caps and a 1 -1/16" cup diameter. Rated at 550ft/lbs continuous.
1350 series .. 3 -5/8" across the caps and a 1 -3/16" cup diameter. rated at 680ft/lbs continuous.
Try and stick with the "solid type" joints and not the one's with a grease fitting. The grease-able joints were weaker as the body of the joint has been drilled out and made hollow for grease.
Richard
Tech Support
Old Mar 5, 2010 | 07:02 PM
Rebelrob's Avatar
Rebelrob
Yep, get the spicers. Well worth it. I got the 1310 and 1350's on mind. But I had a trans shop press them in for me. Got them at a big truck supply parts store.
To U-joint ?
