c3 tach filter
Old Mar 6, 2010 | 10:03 PM
johnrodz's Avatar
johnrodz
Default c3 tach filter
i purchased a 81 c3 w/no motor . i instaled a 1988 L98 with tuned port injection . just read a post about the need for the tach filter . didn't know i needed one . i havent hooked the tach up yet .is it for raido supression or something to do with the tach itself ? part number or doe's someone have one they will sell . johnrodz
Old Mar 7, 2010 | 08:04 AM
AT-82Collectors's Avatar
AT-82Collectors
I am not sure about your engine but in my 82 the filter smooths out the rough edges on the pulses from the distributer to avoid false triggers and also helps protect the electronics in the tach itself.
The filters can be found here:
http://ecklers.com/search.asp?action...searchHistory=
Hope that helps
Andy
Old Mar 7, 2010 | 08:32 AM
Ganey's Avatar
Ganey
Check to see if it's on the firewall.
Old Mar 7, 2010 | 09:27 AM
johnrodz's Avatar
johnrodz
what happens if you didn't use the filter
Old Mar 7, 2010 | 10:21 AM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
If you don't run the filter the square signal from the distributor can be interfered with.
It is not a must and some here will run their cars without the filter. About the only time we will run a car here without a filter is when we are testing the tach for problems.
We have the replacement filters listed in the forum special section at this link. http://willcoxcorvette.com/advanced_...eywords=filter
Willcox
Old Mar 7, 2010 | 11:51 AM
johnrodz's Avatar
johnrodz
Thank you, this is good to know.( INFORMATION IS GOOD) Johnrodz
Old Mar 7, 2010 | 12:06 PM
AT-82Collectors
Yes on what Willcox said. I should have checked their site first, prices are better and support is excellent.
Andy
Old Mar 7, 2010 | 08:53 PM
0Willcox Corvette
Former Vendor
No problem AT..
I just roll with the flow.. I made the boards so I've got a pretty good back ground on the entire system.
Willcox
Old Jul 15, 2010 | 07:26 PM
6mn Vette's Avatar
6mn Vette
Default tach filter
Will the tach filter affect the tach when the turn signals are blinking?...i notice that I can get a little bounce with the tach needle at idle that coincides with the blinkers going on and off.... this is on an '82.
Thanks!!
Old Jul 23, 2010 | 12:01 AM
ssenay72's Avatar
ssenay72
Mine acts weird with the headlights on, does that bounce thing.
Old Jul 23, 2010 | 11:15 AM
7T1vette's Avatar
7T1vette
The tach signal is a stream of pulses coming from the distributor. The circuit board converts the pulse frequency to a voltage for sending to the tach gauge. If your electrical system sends some random pulses or voltage differences through the tach system (consider it 'noise in the system) for whatever reason, the board will consider it to be additional pulses/signal and include that in the tach reading. The tach filter smooths out those unwanted inputs and assures that the tach is only getting input from the distributor pulses. That filter does perform a similar function to the radio filter capacitors, but the tach filter circuit is a bit more complex. A radio capacitor [alone] will not perform the tach filtering job adequately.
To c3 tach filter
