new engine for my 79
Any ideas.
350 GM Goodwrench Engine Kit, Stage 1 - $2275.85
GM Goodwrench 350 Crate Engine Specifications:
* 249 HP @ 5,000 RPM
* 304 Ft/Lbs @ 3,500 RPM
* 8.50 to 1 Compression Ratio
* 4 Bolt, 2 Piece Rear Seal, 4.000 Bore Block
* Cast Nodular 3.480 Stroke Crankshaft
* Cast Iron Heads, 76cc
* 1.940 / 1.500 Valves
* 0.390 / 0.410 lift, Hydraulic Camshaft
* 195 / 202 Duration @ 0.050 Lift
Stage 1 Kit includes:
* Edelbrock Performer Intake (Non-EGR style intake)
* Edelbrock 600cfm Carb with Electric Choke
* GM Intake Gaskets
* ARP Intake Bolts
* Chrome Bowtie Valve Covers, Wing Nuts, and Dipstick
* New MSD Street Fire HEI Distributor
* 350 Goodwrench Engine #10067353
If you go with cast iron heads you might want to stay with 9.5 or below compression so you don't have overheating problems.
