Steering Coupler Replacement
Old Mar 8, 2010 | 07:47 AM
MIKE80's Avatar
MIKE80
Default Steering Coupler Replacement
I need to replace my steering coupler on my 80. Does anybody know where I can get a GM replacement or an OEM spec replacement? I know some of the aftermarket types may use a rubber insulator that does not have the 7 plies that the original GM coupler had. Plus, they might use bolts instead of the shoulder studs.
Old Mar 8, 2010 | 08:22 AM
Grumpy 427's Avatar
Grumpy 427
I got mine from Bairs corvettes.
Old Mar 8, 2010 | 11:18 AM
glassman74's Avatar
glassman74
Got mine at Gmdirectparts. glassman74
Old Mar 8, 2010 | 11:47 AM
MakoShark72's Avatar
MakoShark72
GMPartsDirect or any GM dealer can get it..
Old Mar 8, 2010 | 01:15 PM
larryg3's Avatar
larryg3
What is the GM part number for the Rag joint Coupler??
Old Mar 8, 2010 | 01:54 PM
ssenay72's Avatar
ssenay72
Is this a difficult job to do?
Old Mar 8, 2010 | 01:57 PM
MakoShark72
Google is your friend...
http://www.google.com/products?q=gm+...tte&hl=en&aq=f
Old Mar 8, 2010 | 02:00 PM
MakoShark72
Scroll down to Flexible Coupling....No its not hard
http://jimshea.corvettefaq.com/?page_id=4
ssenay72's Avatar
ssenay72
ecklers and corvette america have them
http://www.ecklers.com/product.asp?p...dept%5Fid=1715
Old Mar 8, 2010 | 02:03 PM
larryg3's Avatar
larryg3
Thanks Makoshark 72
Old Mar 8, 2010 | 02:19 PM
wcsinx's Avatar
wcsinx
http://www.duntovmotors.com/FrontSuspensionSteering.htm
Old Mar 8, 2010 | 04:28 PM
Jim Shea's Avatar
Jim Shea
The GM part number for a late 1969 through 1982 flex coupling is 7818568.
Jim
Old Mar 8, 2010 | 05:19 PM
MIKE80's Avatar
MIKE80
Thanks for the info Guys! This is one part that I would like to stick with original GM on.
Old Mar 8, 2010 | 06:19 PM
vettfixr's Avatar
vettfixr
Old Mar 8, 2010 | 06:34 PM
MIKE80's Avatar
MIKE80
Originally Posted by vettfixr
How's that compare to the original? Are your column and gear box stock? Was it a direct bolt in without any mods? Any issues with your steering wheel being off center? Sorry for all the questions
Old Mar 8, 2010 | 06:40 PM
vettfixr's Avatar
vettfixr
No problems at all. My steering is a completely stock 74.
Zero deflection
Zero play
Zero maintenance
The install was pretty straightforward. I dropped the steering box to get the old rag joint off and put the new one on. Mark the shafts to make sure you get the wheel straight. Other than that its about the same as putting on a rag joint. I've had it on for years now with no problems at all.
Old Mar 8, 2010 | 07:34 PM
wcsinx's Avatar
wcsinx
Zero deflection
Zero play
Zero maintenance
NVH?
To Steering Coupler Replacement
Old Mar 8, 2010 | 07:45 PM
Grumpy 427's Avatar
Grumpy 427
Does that part number fit all corvettes? and how hard was it to install. Did you have to remove the steering box?
Old Mar 8, 2010 | 07:46 PM
vettfixr's Avatar
vettfixr
Originally Posted by wcsinx
NVH?
None. It's one of the best mods I've done on my car. Easy, fast, and you don't have to do it again, ever.
Honestly, I hesitate to post this fix because I get a lot of flack about it. A lot of people will tell you that the rag joint makes up for misalignment and flex and shields from harshness and the u-joint is just gonna make your car turn puke green and blow up.
To this I ask why do all new cars come with u-joints. And if flex and deflection are problems how do our independant rears last for 30+ years with 4 (the horror ) u-joints, not to mention the two in the driveshaft? (I know, not a good analogy, but I just got done dinner and I have heartburn. LOL )
All I'll say is I made this swap after going through at least 3 rag joints and always ending up with steering that felt like it was connected by a rubber band. With the u-joint, if you move your steering wheel 1/4 inch, the wheels move the same amount. I have absolutely no deflection whatsoever in my steering.
I just looked back at the pics in the gallery and they were posted in April of 2005. Since then I haven't worried about my steering.
Old Mar 8, 2010 | 07:50 PM
vettfixr's Avatar
vettfixr
Just call Flaming River and they'll set you up with the right part no. I got the number from them and ordered through Summit. I dropped the steering box to do the install because I didn't want to mess around with the column. I understand that you can comperss the column and then pull it back but I'm not that brave.
One other thing, after you install the joint, adjust your steering box to tighten things up. You'll be amazed at the difference.
