help with cast number??
Old Mar 10, 2002 | 03:07 PM
daniel77350's Avatar
daniel77350
Default help with cast number??
I was wondering if someone could check a cast number for me. Its a head number I found when I removed my valve covers(to remove the intake).
The number is 1401441
There is a crazy history behind my car's motor, and I only know bits and peices, but I know its pretty involved...Knowing what kind of heads I have might help solve the problem.
By the way, the intake came off smoothly, everything looked clean, no build up of any sort, just a smooth layer of dark stuff :).
Daniel
PS. Where do I find my engine block cast number? I looked everywhere.
Old Mar 10, 2002 | 03:11 PM
PatsLs1vette's Avatar
PatsLs1vette
Default Re: help with cast number?? (daniel77350)
14014416...80-86...305..........1.84"/1.5" valves, 58cc chambers
did you forget a number thats the closest i could come up with or a 14014415 too14014415...80-85...267/305
your casting number for the block should be on drivers side behind the head.
[Modified by pats406nitrovette, 2:12 PM 3/10/2002]
Old Mar 10, 2002 | 03:25 PM
daniel77350
Default Re: help with cast number?? (pats406nitrovette)
thanks for the info....the last # is a 6...
what is "80-86" and "305"...what do those numbers mean? And is there any way to tell if they are stock to a '77 1-48?
Daniel
Old Mar 10, 2002 | 03:27 PM
PatsLs1vette
1980 - 1986 motors used in and the other is valve size...and 58cc small chamber heads..most likely 305 heads..are you sure it s a 350 or a 305 now thats in the car?
Old Mar 10, 2002 | 03:29 PM
daniel77350
a 305? god I hope not...if it is, anyone have a 350 for sale? :jester
Daniel
Old Mar 10, 2002 | 03:30 PM
PatsLs1vette
check your casting number on the back of the block drivers side and see what it is and then post it....
Old Mar 10, 2002 | 03:32 PM
daniel77350
can I see it with the block in the car? I'll look...
Daniel
Old Mar 10, 2002 | 03:40 PM
daniel77350
ok, these are the numbers I came up with, from top to bottom:
376
86
140 N
I dunno if thats what's needed or not, but those are the only ones I found.
Daniel
Old Mar 10, 2002 | 03:49 PM
daniel77350
the intake number is 346249 I think
those are the only numbers I can get to.
Daniel
Old Mar 10, 2002 | 06:33 PM
4_inch_Bore's Avatar
4_inch_Bore
Your intake is from a 76-82 305 or 350, used on all cars.
You need to find your block casting code, something like 3970010 (350) or 14010202 (305).
Also check the stamp pad on the pass side, below the front of the valve cover.
Old Mar 10, 2002 | 06:35 PM
daniel77350
Default Re: help with cast number?? (4_inch_Bore)
go to this thread:
http://forums.corvetteforum.com/zerothread?id=254530
PatsLs1vette
daniel ifs right behind the drivers side head on the block ill take a picture of mine to give you an idea.
Old Mar 10, 2002 | 06:37 PM
daniel77350
go to the url I posted...it gives my cast number, and the info I found on it...its very depressing info. :)
Daniel
Old Mar 10, 2002 | 06:45 PM
Stingy74's Avatar
Stingy74
Here's where some numbers can be found. I circled where.
Old Mar 10, 2002 | 06:49 PM
daniel77350
Default Re: help with cast number?? (Stingy74)
thats where I found my numbers...actually mine is just like that...apprently thise can be more then just 302? according the site I found its 302..but someone said it can be anything...but my heads are 305, and my intake was used on 302/350....
I told my dad and he said "No wonder it didn't feel like a 350"...so maybe it is a 302, or a underpower 350(compared to the stock 350 that was in the car when my dad got it, before he put in a 400, which was before this block was put in)..
Daniel
To help with cast number??
