I know this is a dumb question, but what is the spark plug gap supposed to be on a stock 77 L-82 4 speed? I think mine is set too tight. I'm getting a lot of carbon build up on them.
My 79, L-82's spark plugs are set at .045. I had trouble with fouling and discovered the carbuerator idle was set too rich. I leaned the idle out as much as I could and still maintain a good idle. This solved the problem.
Too close a gap could result in a lower spark energy and/or [certainly] a smaller spark length, which may cause missed ignition firings, poor mileage and low power output. Interestingly, too wide a gap can cause the same symptoms...but because there isn't enough spark energy to jump the widened gap.
Plug gap is a function of the level of spark energy available in the ignition system, primarily due to coil design. So, folks would do best to set their plug gap to what the maker of the ignition system recommends.
From: I tend to be leery of any guy who doesn't own a chainsaw or a handgun.
The plug energy is independent of the gap size. Energy is determined by the coil inductance and the primary current, not the plug gap. The plug gap only determines the arcover voltage (and not the coil, as many aftermarket coil manufacturer advertisements imply).
I agree that going with the manufacturer's gap spec is the best default position.
Default for a condenser/point system is factory 35 point gap. Sometimes you have to play the game and wonder how safe the factory wants you to be with the car they built. Like setting total timing. My point gap is at 33. Yes, could effect low rpm performance but when that engine is reving and there is less time for that coil to charge and discharge, the closer gap helps that spark jump the gap. Also don't run resistor plugs and up the dwell a point or two for longer charge duration. Works for me. That was for guys w/o an HEI setup.
