rear spring
Old Mar 8, 2010 | 05:24 PM
mlars's Avatar
mlars
Default rear spring
Will a c4 rear spring fit a 78 corvette? composite.
Old Mar 9, 2010 | 07:23 AM
muskegonbrake's Avatar
muskegonbrake
Supporting Vendor
No, the mounting is different. The C4 is designed to be mounted to the aluminum rear ends (36 or 44). The 78 has a 2 1/2" spring mounted to the cast rear end cover, different bolt pattern altogether.
Old Mar 9, 2010 | 07:57 AM
mlars's Avatar
mlars
Thanks, my 78 has a heavy duty 7 leaf spring in it now, it rides very stiff and I want to get something softer. Does anyone now what # rating composite spring I should use for a smooth ride?
Old Mar 10, 2010 | 08:52 AM
muskegonbrake
Supporting Vendor
I recommend a 315# or 340#, both will give you a better ride than what you have. Make sure you check the mount bolt size and current spring width.
To rear spring
