Sand blasting frame on
Old Mar 9, 2010 | 11:01 AM
ANY VETTE's Avatar
ANY VETTE
Default Sand blasting frame on
Can you sandblast with frame on?
Old Mar 9, 2010 | 11:32 AM
crf311's Avatar
crf311
No way I would ever try this. One slip and it's a new paint job
Old Mar 9, 2010 | 12:37 PM
Roco71's Avatar
Roco71
You will have sand in areas that you did not think sand could get into.
Old Mar 9, 2010 | 01:42 PM
claysmoker's Avatar
claysmoker
St. Jude Donor '09-'11-'12-'13-'14
guaranteed! Don't try it, you'll regret it until you die. Maybe longer.
Old Mar 9, 2010 | 04:12 PM
ANY VETTE's Avatar
ANY VETTE
Thanks I guess i won't my frame is pretty good but sand blasting seemed like a quick way to clean it up and then paint.
Old Mar 9, 2010 | 04:15 PM
Faster Rat's Avatar
Faster Rat
2024 C3 of the Year Finalist - Unmodified
Sand blasting will destroy most non-frame areas and parts. You need to go the undercoat scraping, degreasing, washing, wire brushing and wire wheeling route, preferable with a pneumatic die grinder. I would suggest removing the driveline and suspension parts first and restoring/rebuilding them off the car. Certain parts can be final cleaned in a fine glass bead media cabinet, but not all. There is no quick and easy way to this, especially laying on your back with the car on jack stands. Have fun.....
Old Mar 9, 2010 | 05:30 PM
Mia's Avatar
Mia
Sand = MESS... You'll never get rid of it all.
Pressure Wash
Wire Brush
Wash again
POR 15
That's about it. It'll look pretty and never rust again. Do things in sections and take your time. You'll be glad you did.
Old Mar 9, 2010 | 06:09 PM
7T1vette's Avatar
7T1vette
Sure....you can. But not me.....
But, if you're just trying to clean the grease and grime off of it so that you can paint it, go to a steam cleaner's instead. It's like using a steam pressure washer. Just show them where you DON'T want them to blast (sensitive wiring, electrical parts, anything you would rather clean yourself than take a chance on damaging), and let them 'have at it'. It will cost you somewhere around $200-300 to have the job done right. {You can probably get it done for less, if you want the job done WRONG.}
Old Mar 9, 2010 | 08:02 PM
jordan89's Avatar
jordan89
Pressure Wash
Wire Brush
Wash again
POR 15
That's what I'm planning on doing with my Vette since I'm not doing a frame off resto.
Old Mar 9, 2010 | 08:17 PM
Billysvette's Avatar
Billysvette
Ok ,yes you can ,i did it and its still holding up,i did have the motor and trans removed,all wheels off and jacked up.It was a long process and DIRTY,But it will work,i am proof of it.It is best to do a frame off but i had no room to do it and no place to do it at.It turned out really good and i was able to get almost every part of the frame.It has bee 15 years since i did it and it still is great looking no rust at all.But i donot drive in the rain or snow.Go ahead and do it and just take your time,it will work.I did remove all oil and grease,and when done blasting i took air hose and blew out andy sand residue.I am surprised that nobody has given you a better response.
Old Mar 9, 2010 | 09:13 PM
noonie's Avatar
noonie
You can do soda blasting with no problem.
It just dissolves with water, so the cracks and crevices issues with sand doesn't apply.
To Sand blasting frame on
