1973 heads appear different?
Old Mar 9, 2010 | 11:13 AM
Txslugger73's Avatar
Txslugger73
Default 1973 heads appear different?
Have a 60k '73 with matching # engine but noticed that the forward part of the two heads appear to look different. The left head has what looks like an "M" design on the front vertical area, while the right head does not. Is this correct?
Old Mar 9, 2010 | 11:32 AM
Vetteaddiction's Avatar
Vetteaddiction
The one with the "M" is probably an L82 head (twin peaks). If you pull the valve covers you can check the part numbers and date codes.
Chris
Old Mar 9, 2010 | 11:54 AM
Mike Ward's Avatar
Mike Ward
Look on the rear surface of the right head.
Old Mar 9, 2010 | 01:00 PM
Txslugger73
what am I looking for?
Old Mar 9, 2010 | 01:13 PM
Mike Ward's Avatar
Mike Ward
an M like on the other head.
Old Mar 9, 2010 | 03:49 PM
Txslugger73
will do. if the "M' appears on the back side of the other head, does it mean the heads are at least matching? And if matching, is this correct for the standard L48?
Will have to wait a few days to check...car is in paint shop being touched up.
thanks
Old Mar 9, 2010 | 08:35 PM
vettehardt's Avatar
vettehardt
If you think about it, the front of the head on one side will be the back of the head on the other side. The heads can go on either side but one has to be turned around as compared to the other side.
The only way to truely know if they are the correct heads is to pull the valve covers and look at the casting numbers. Most of the heads for the 350's (and even some 305's) look the same from the out side.
To 1973 heads appear different?
