Plug wires melt
Old Mar 13, 2010 | 01:45 PM
thiatt's Avatar
thiatt
Default Plug wires melt
Anybody else have this problem? I have headers installed. Even though I have used high temp wires, and be careful to keep the wire in side the factory raceway. They still melt where the come to the plug. The most space I can keep between the wire and header is 1/2".
Anybody have a solution? Should I just run them on top the valve covers?
Old Mar 13, 2010 | 02:32 PM
Fonz69's Avatar
Fonz69
Welcome to our nightmare
The best way mine have survived is going above the headers and using 90 degree boots with heat socks and wire looms
good luck
[IMG][/IMG]
Old Mar 13, 2010 | 02:55 PM
thiatt's Avatar
thiatt
That's a nice setup! I like how they don't interfere with valve cover removal. I'll something like that. Thanks for the tips.
Old Mar 13, 2010 | 03:16 PM
midyearvette's Avatar
midyearvette
if your mill is melting wires close to the plug and you have 1/2" clearance, i would check my total timing as it could be too slow or weights sticking....too much header heat is a sign of slow timing....good luck....
Old Mar 13, 2010 | 04:40 PM
ED69ray's Avatar
ED69ray
I use these plug wire guards on both my cars
Purchased from Jegs - a little pricey but better than havin to replace wires.
Good Luck, Ed
Old Mar 13, 2010 | 06:28 PM
thiatt's Avatar
thiatt
It only melts them after sitting and idling for long periods of time. (like when I was tuning the carb, or just letting it run after sitting for couple weeks.) Air flow of driving seems to prevent it, however I will check my total timing. By this you mean full vac advance and mech. advance, all in timing? Or just mech?
To Plug wires melt
