I have a 1975 Vette I have purchased to modify and make a "Toy" to play with. Everything was going well until I closed my hood. I had the hood off to paint the under side and to replace the insullation. I was proud of my efforts until I closed the hood and it has been three weeks since I have been able to open the hood. It is stuck on the drivers side. I have tried shaking, proping the passengers side up and tripping the latch with a pole, pulling off the drivers side tire to reach the latch, etc... and nothing has worked. I had rather figure out how to fix the hood rather than taking it to a body shop.
Has anyone had this problem with a C-3 if so how was the problem fixed?
I'm looking for some similar help- except that it's my hood release cable that broke. So, both sides are still latched down in the locked position. Same suggestions? It's a 1976 L82, so it does have the rise in the center of the hood.
Thanks in advance!
Marcus
Not being smart but I hope you have good luck. I am going to try the suggestion above . Believe me I have pulled out the hair on my head and now I am working on my beard.
I have used a lot of your suggestions and they have been very helpful but I haven't got the hood open yet. I have the passenger side open and I can create a 6" to 8" gap on the passengers side and I can see the drivers side latch that won't open. I can trip the latch but something is preventing the latch from releasing. I have one more idea I am going to try, I plan to use a piece of 1\2" tubing and place a metal wedge on the end and try to wedge the hood open. If I tear up the latch so be it and I will put a new latch on, probably replace everything on the hood. If it breaks the hood I will cuss and stomp and cry and buy a new hood.
Thanks for everyones suggestions and I will keep you posted - success or give up.
Don't you will probably break the hood. Get something connected on the pass. side if you need to open again & get something hooked on the cable for ex. if needed for dr. side. Close pass side & work on opening dr side, best to open both at once.
There are good pics. in this topic which should help you see what you are working with to do it. http://forums.corvetteforum.com/c3-t...uck-hoods.html
You might try shooting some lube in there to help. There are other topics on closed hoods w/ the latch system you have.
My latch system is different from yours. I did a write up on my type (which was not sent as it would not help) & sent to many who have opened theirs.
I am in the same boat with my 74. Replaced motor put on the hood and the dang thing is doing the same thing as yours, left up and right stuck. I'll let you know if I get mine somehow.
This is intended for others reading this thread:
Anytime you want to remove the hood, make certain that you mark the location of bolt heads, outside edges of brackets and latch frames, etc. It's the only way to limit [not prevent] the problems described above.
[Hope you are able to get the hood back in line without any damage. ]
Sorry for the late reply - I have been on jury duty and have to return tomorrow. I still do not have mine open. I have taken pictures of the stuck side. I have enough gap on the passengers side to get a camer underneath the hood. I hope to post by the end of the week if jury duty does not take up too much time and I don't forget my camera again. I did find a corvette shop in Birmingham that specializes in the older vettes but they are only opened Monday thru Friday so it will be next week before I get mine into town.
I have given up after a month of trying. I have found a corvette shop in Birmingham that works on the older vettes and I will be taking it to them week after next, they are at the corvette convention next week.
I really appreciated everyones help and comments. There is good people in this forum and maybe someday as I learn more about these cars I can offer comments and support to someone.
I just did my 75. Jack up the drivers side. Right behind the front wheel on the bottom is a piece of metal/seal that seals the bottom of the fender with three bolts. two on the bottom and one to bottom of the body. Remove the three bolts. Remove three more bolts directly behind the drivers side tire to remove a black canister in the fender well. Once removed, you can reach up and around the brake booster to get access to the hood release levers.
Can you buy these? If so, Where? I don't have the skill set to fabricate something like this.
