Oil dip stick "HEADACHE"
Old Mar 19, 2010 | 01:49 PM
us marine's Avatar
us marine
Default Oil dip stick "HEADACHE"
When I installed my headers I took it out. After putting it back in it started leaking.
Looks like I didnt have it seated properly.
Tried all day yesterday and couldnt get it to go in.
Any Ideas?
Old Mar 19, 2010 | 03:24 PM
427390's Avatar
427390
pull it back out and clean it and the oil pan (where it fits in) with brake or carb cleaner to get rid of the oil. put a very light coat of rtv on the part that fits into the oil pan and seat it (maybe a light tap on the end to make sure) - let the rtv dry and you should be good to go
Old Mar 20, 2010 | 01:54 AM
us marine's Avatar
us marine
Cleaned it up pretty good but if feels like its hitting after it passes through the first small hole. I know its not seated all the way in since it hasnt gone down to the lip.
Also when I try just to put the dip stick in it is not even going into the block. I cant seem to find the block opening. Driving me crazy.. Is it possible something shifted and the hole is moved?
Old Mar 22, 2010 | 12:30 PM
us marine's Avatar
us marine
Had to drop the oil pan what a pain but found out that metal shrowd was blocking the tube from going in. Put some sealant in it and wham its now in like a champ.
To Oil dip stick "HEADACHE"
